SOURCE: connections for home entertainment system to tv
has your problem been solved or not. If not, please explain breefly about your connection to your audio or Tv.
SOURCE: Samsung home cinema system HT-THX25 Multiregion hacks
Turn on the HT with no DVD. Press the following buttons on the remote: ENTER 8, 4, 2, 6, 9 ENTER
It will turn off. When turned again on it is a region free HT.
SOURCE: I need to reset the region code on a samsung home
Hi
Thanks for using FixYa. Please follow this procedure to reset the region code (or to make it region free).
Open tray and remove any disks in tray, then Close the tray.
1. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
2. Reconnect to mains
3. Turn on player with remote.
4. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9. Using keys on remote.if your player is already set to region 2
6. Press ENTER on remote. (The tray will open and player will power off and close tray.)
7. Switch on power from remote.
8. Player is now Region Free.
Allows both region 1 & 2 DVD's to play.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
SOURCE: Samsung Home theater system
i have the same problem, i've eventually resorted to putting a box fan next to it and taking the cover off....kinda ridiculous but beats buying another unit and this point
Latest firmware is..
HTB-C6930WWB-1016.2.zip
This can be downloaded (with instructions) at http://www.samsung.com/uk/support/detail/supportPrdDetail.do?menu=SIA00201&prd_ia_cd=802&prd_mdl_cd=HT-C6930W%2FXEU&prd_mdl_name=HT-C6930W%2FXEU&srchword=HT-C6930+3D+Blu-ray+5.1+Home+Entertainment+System
If you already have this firmware then you need to contact Samsung.. The last upgrade was 5th oct 2012.. not good enough Samsung.. :(
I emailed support at Samsung and they told me to hold down the stop button and this would bring me to a setup menu. I have never had a setup menu and can't get anything to work when I do see setup on the unit.
