Any idea what could be causing this?
SOURCE: got my key washed in the washing machine can you help?
The best solution is this. Open the remote take the batteries out. You then pop the two sides off, or if you have the screw type you can do it that way. once you have it open, then all you have to do it USE alcohol to clean the board with a old toothbrush. use a hair dryer to dry it out and let it sit near a fan or sunlight for about 1-2 hours, someplace the air flows. snap it back together a nd presto, you dont need to replace it. I did the same thing 2 months ago, and I deal with electrical items every single day.. the most important thing is to rinse it with Clean water distilled prefered to make sure there is no pesty chemicals from the city water. thats what messes it up!!!!.. good luck
SOURCE: My washing machine basin on a Whirlpool top has come loose.
Hello, down the center of the agitator there is a nut. You need a very long socket shaft to get to it, tighten this and it shold solve your problem. I hope this helps.
SOURCE: kenmore washing machine went off balance now won't
no there is no reset button.When you say off balance im thinking of a machine jumping around the floor if this is the case then something has come loose or the balance block has broken inside your machine.adrian;;;;
SOURCE: just had sears deliver kenmore top loading washing
Hello. Chances are it is not level. There are leveling pads at floor level at all four corners. You can level it yourself or [what I recommend] call the store and complain. You paid for delivery and setup and they did an unacceptable job of it. Insist that they come back and do it correctly.
SOURCE: My washing machine is smelly!! I was told that I
You don't neeed to remove anything Just set it to large load hot water and add 2 cups of bleach. Run it through 2 cycles. If the smell is still not gone completely repeat.
Never had this fail.
Hope this helps
Please leave feedback
It is so common that the washing machine can make
terrible noise in many ways and is a common fault. In all occasions it is
important that your observation is most important and so is vital to the
identification /rectification and solution. If you have noticed that machine is
vibrating when it is running then the motor /drum suspension has to be
inspected. Since these fittings are located on the underside of the machine it
is important that you look for the noise with a good inspection lamp. Manually
turn the motor and drum and listen for the noise, if so the motor bearings, the
drum agitator shaft and fittings must be checked. Also the suspensions which
include the shock absorbers and springs, the body clamps must be checked to be
in correct alignment and not changed in position. Tightening of the
mounting is also very important. Finally
in most cases a drop of OIL or smear of grease on the moving parts cane solve
most issues.
check this link:
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
