First of all, unplug the unit before working on it. Be careful inside a fuse box, dangerous voltages. It's usually safe to change fuses or flip a breaker so long as your not in a wet location. Most dryers run the heating element on 220 volts, meaning you can either have one larger breaker or you could have 2 smaller breakers or fuses. If that is the case, possibly one of these breaker "legs" has tripped. Check that first. I would sooner think one of the heating elements are open or "not heating". I would look up the Roper Model number and search for the heating elements section. Some do have a thermal fuse but I think that would cause both elements to quit. Take a look here: https://www.youtube.com/results?search_query=roper+dryer+heating+element+replacement
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
http://www.repairclinic.com/0088_8_1.asp
Heating element
Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
SOURCE: roper clothes dryer not drying clothes
Please take a look at the following link. In particular, the first major paragraph where it discusses proper ventilation:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
I know the link is for a dryer that no longer heats, but if a dryer is left in a condition where it is starved for air, the heating circuits will actually over-heat and eventually fail. You need to ask yourself when was the last time you inspected or cleaned the dryer exhaust ventilation. If you can't remember, or if you've never cleaned anything before, it may be a good time to do so. Most dryer heat related problems are caused by poor ventilation and lack of cleaning. I recommend that you clean the dryer ducting twice a year. That's once in the spring, and once again in the fall. It is also important to note that the SHORTER and STRAIGHTER the exhaust vent line is, the BETTER. The more bends and kinks that you put in the dryer exhaust, the more resistance you create for the dyrer blower, and the more potential choke points you create where lint can accumulate and clog. Not to mention, this can also cause a fire hazard and/or a habitat for rodents.
Follow the recommended advice and try drying a load of clothes with the vent hose removed, first. If your clothes dry faster like they should, you may have an exhaust clog somewhere. If your clothes still aren't drying correctly, inspect the interior blower fan housing for obstructions. This is all explained in the link provided.
If you attempt these preliminary measures and still have problems, please let me know. I hope you find this information helpful.
SOURCE: blowing cold air-no heat to dry clothing-how do i know it is the heating element that is bad?
you have to see if you see any broken wire on it,also there should be a fuse on the top left side of the heater box at might be bad,let me know what you find-mike
SOURCE: dryer takes 2 to 3 cycles to dry clothes
check temp coming from vent back of dryer should be 160
SOURCE: bosch axxis wtl 5410 dryer takes too long to dry.
You should have a cycling thermostat. this is most likely bad or your dryer vent may be clogged. Something is cutting the heat off before it gets hot enough. Both these cause this problem.
