Favorite channels are programmed sckipping some. Find on the tv the settings and reset the channels and you can see them all again.
Testimonial: "STILL SAME THING I HAVE ALSO TRIED A COMPLETE RESET ON TV AND REST TO FACTORY SETTINGS STILL NO JOY. THESE PROGS ARE ALSO NOT AVAILABLE ON A FREE VIEW BO I HAVE THE CHANNELS MISSING ARE ITV/ITV2/CHANNEL 4 AND CHANNEL 5"
SOURCE: magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
SOURCE: Skipped channel 4
I have the EWF2004 emerson TV. I tried a ONE For all universal remote and programmed it for a FUNAI TV code 0179 and it worked!!!!!!
SOURCE: cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
SOURCE: Lost ITV channels and C4
I think you need to get Sky because it will give you 100% coverage of all terrestrial channels. You may need to retune the television otherwise just get sky
