SOURCE: my asko dw 3250 is
Please refer the user manual for your model.
The 2 flashing lights you have mean the drain is blocked.
See page 13 of manual for possible ways of cleaning the drain.
Please post a comment to confirm if you were able to clear the fault or not.
SOURCE: ASKO washer Model #10505, front
Hi, When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
You have unplugged it and it still is stuck
