Tablets & eReaders Logo
E
Elias kola Posted on Dec 24, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can u help me to unlock my iPad please - Tablets & eReaders
Hilux2001
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Dec 24, 2017
Hilux2001
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
2794
Points
28
Press home screen button and Off button simultaneously for a few seconds, then turn on your IPad
Pierre Legault
Level 3:
Master:
  • Master 388 Answers
Pierre Legault
Master
Level 3:
Master:
Answers
388
Questions
0
Helped
96565
Points
1178
Https://support.apple.com/en-us/HT204306
2answers
How to unlock an ipad
If you remember the password of your iPad, it's would be easy. However, you can still refer to below steps to unlock an iPad without password.
It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
Method One: How to unlock iPad without password using iTunes
  • 1. Connect iPad to the computer you have synced with.
  • 2. Open iTunes on your computer and connect it with your iPad. If fortunate, you can enter the iTunes without password. But in most cases, there would be prompt asking for a pass code. Try another computer you've synced with, or use recovery mode. (The recovery mode will be mentioned in method three.)
  • 3. Find your iPad in summary and make a manual backup. Once the backup have finished, click Restore your iPad with the most relevant back-up.
Method Two: How to unlock iPad screen without password with iCloud
You can also use iCloud to remove your password and recover your data if you have backed up before it was locked. And it is in the premise that you have set up Find My iPhone on your iPad, and you did remember your Apple ID, you can use iCloud to unlock your iPad.
  • 1. Open your laptop or computer, go to icloud.com/find or open the iCloud app.
  • 2. If the sign-in window pops up, just sign in with your Apple ID.
  • 3. There's an All Devices button at the top-left of the window, click on it to call out a drop-down menu and choose your iOS device.
  • 4. Click Erase (your device) in the prompt to finalize the process.
  • 5. Now you can either recovery data to your device from a backup or set up as new if there isn't any back-up before.
Method Three: How to unlock a disabled iPad in recovery mode?
If you've neither synced with iTunes nor set up Find My iPhone in iCloud, you'll need to wipe your iPad to factory setting to remove the password, which means you'll suffer losing all your data on iPad and get it as a new one.
Please pay attention there is a slight difference in putting different models of iPad into recovery mode.
iPad Air
  • 1. Turn off your iPad Air, press and hold the Home button.
  • 2. While holding the Home key, connect the USB cable to the device. Wait until the Apple logo appears and keep holding the Home button for few more seconds.
  • 3. Continue holding the Home button until the iTunes logo appears.
iPad mini/iPad pro
  • 1. Connect your iPad to your computer or laptop and open iTunes.
  • 2. While your device is connected, force to restart it.
  • 3. Press and hold the Sleep/Wake and Home buttons at the same time. Don't release when you see the Apple logo. Keep holding both buttons until you see the recovery mode screen.
Now you have entered the recovery mode, and
1. When you see the option to Restore and Update, click it.
restoring-ipad-software-cpmn0ithqpr5j0kd3fh1ly4i-5-0.png For more details, check: How to Unlock iPad
I need help with the passcode for my ipad
Is there anything wrong with the passcode? If your iPad is locked and you forget the passcode, please follow the steps below to unlock it.
1.Connect your iPad to your PC or Mac.
2.Select your device in the iTunes sidebar, and click the"Summary" tab.
3.Click "Check for Update". iTunes will show you if there any new version of iPad software is available.
4.Click "Restore iPad". You can finish the restore process by following the instructions given. During the process, a recommend that tells you to back up your files will be given. You can restore your data after the process is complete.
Now, you must have restored your iPad.
Note: Even you bring your iPad to the Apple service center, Apple staff also need to restore your iPad to unlock it. That's to say, you need to erase everything on it.
http://www.leawo.org/tutorial/forgot-ipad-screen-lock-password-how-to-recover-data-from-locked-ipad.html
1helpful
3answers
How do i fix my disable ipad
Go to iTunes then sign in, connect your iPad to the PC/Laptop and factory reset the iPad, that is the only way it can be done!
2answers
My iPad is disabled and i don't know what to do i've gone on iTunes but nothing seemed to work,what should i do please help me.do you think that you can help me
disabled how if icloud locked we or itunes cant help you --if battery or screen problem bring to a repair shop or sony store
How can I login to my iPad when the passcode isn't working?
You have to reset your iPad. Just follow below steps.
How to unlock iPad without password or how to unlock disabled iPad? It is a good habit to have your iPad backed up regularly. In case of your iPad is locked, disabled or being stolen, you can easily recover your data from it. Otherwise, you'll lose all the data. To unlock iPad screen without password or to unlock disabled iPad mean you have to remove your previous pass code and restore your iPad. Here we introduce three methods which you can follow.
iPad Air
iPad mini/iPad pro
2. Wait for the process to finish. Then you can set up and use your device.
itunes-summary-4wdcyutupah1kirb0sfrwsm2-1-0.png For more details, check: How to Unlock iPad without Passcode
I forgot my ipad code
If you have an iPad with iOS 7, you can't open the iPad. After you put in the wrong pass code 3 times, you only can unlock the iPad with the correct password, belonging to the Apple ID from what only a part is shown on the screen. If you don't have the passcode nor the password Apple assumes you are not the legal owner, and you can't use the iPad anymore. If you goto an Apple store and take your iPad and the invoice with you and some ID, so you can prove you are the owner, perhaps they can help. But if you can't prove the iPad is yours, don't go there, they will not help.
2helpful
3answers
How to unlock jailbreak on iPad?
If you prefer a simple yet fast solution to jailbreak your iOS device. You can take a try of AutomaticiPhoneUnlockers.com, it can help jailbreak or unlock as many iPad, iPhones, iPod Touches as you like. Both Windows & Mac OS X are compatible.
1helpful
Haven't used my ipad in a while, and forgot my password to unlock. help
click on Safari, click on open book icon, top of page, find iPad help on drop down menu...(last one)
1helpful
How to unlock ipad for free
It is possible to unlock your iPad (or other iOS devices) now. And if you prefer an easier way to do the job, see how you can achieve it on your PC or Mac on your own from this website: www.automaticiphoneunlocker.com
Top Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
