RCA Scenium HDLP61W151 61 in. HD-Ready Television Logo
Posted on Jul 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a computer with HDMI output and my Scenium has HDMI input but I get no picture when I play movies on my HP 9700 computer that I would like to have displayed on my RCA Scenium. All connections seem complete. Am I attempting the impossible?
Anonymous
Level 2:
Novelist:
  • Expert 85 Answers
  • Posted on Jul 30, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
85
Questions
Helped
38945
Points
195
(No longer listed on Amazon.) The most likely reason for no display is not matching the scan rates. Your TV is either 1080i (1920x1080x30) HxVxrate or 720p (1280x720x60) high definition. That's its native display but it may accept both but not 1080p. The computer must be set to one of those. The TV will not accommodate, well it may accept 480i or 480p (720x480x30 or 60) for standard definition and that could be 640x480. Go to your computer display controls and see which resolutions are available and it may be different in mirrored versus extended mode. If the signal comes from a TV DVI source and is converted to HDMI, it will not include sound. There may also be a problem with copy protection (HDCP) as your computer may be fussier than the TV. -Ken
How do i connect my laptop to my RCA SCENIUM?
If your TV has a VGA input you can enable monitor 2 on your laptop and use the external vga output
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
How do i get a movie to play from computer to the tv with hdmi
If your TV has an HDMI input - connect up the computer to the TV with an HDMI cable.
Select HDMI on the TV inputs.
Play the DVD on the computer, should appear on TV is Input is set. Sound may be a fiddle ~ check you PC sound settings if there is none.
The computer will usually show a blank screen when the HDMI is going elsewhere,
Good luck
I have a 60" Mitsibishi TV and I am trying to
When your notebook computer is connected to an HDMI device, you may encounter certain display and sound issues. For example, if you have your notebook computer connected to an LCD TV and/or surround sound speakers with a high-definition multimedia interface (HDMI) cable as part of a home theater system, you may encounter some common HDMI display and/or sound issues such as the following: If you are experiencing one of the following issues, click the link to go directly to a section of this document for a resolution. If you are experiencing an HDMI display or sound issue that is not listed above, please contact HP for assistance. Set HDMI sound output c02654744.gif Make sure that HDMI device is enabled and selected. To make it the default sound playback device, select ATI HDMI Output and then select Properties . The HDMI cable must be connected when it is configured. Use correct HDMI cable for your HDMI device There are three types of HDMI: 19-pin (normal head), 19-pin (small head), and 29-pin. If your computer and HDMI device use different cable types, adapters are available. For more information, see HP Notebook PCs - Overview of HDMI and DVI Connections for PCs . Content protected error message If you are playing an HD DVD on your notebook computer while it is connected to an LCD TV with an HDMI cable, you may see an error message that reads, The content is protected. The content is not allowed to be played in current mode. This error sometimes occurs when single mode settings are selected. To resolve the issue, click to accept the message when prompted, and the movie will play. images do not display properly When the notebook computer is in HDMI mode, images sometimes are distorted or do not display at all. To resolve this issue, use the HP Support Assistant to test your computer and install any updated drivers. Alternately, download and install the latest NVIDIA GeForce driver from your model from the HP Software & Driver downloads page . For more information about downloading and installing drivers for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document. Surround sound option is unavailable First, confirm that your notebook recognizes HDMI audio by right-clicking the Volume icon in the Windows system tray and selecting Playback Devices . If you do not see HDMI Output then you may need to reinstall or update your audio drivers. Also, make sure your notebook's BIOS is up-to-date. When using WinDVD to play a movie after selecting HDMI as the default audio output, the surround sound option may be unavailable. To resolve this issue, please update to WinDVD version 9.0 or later at the HP Software & Driver downloads page . If you are using the MediaSmart program, make sure you are using the latest version. For more information about downloading and installing software updates for your HP notebook computer, please see the Locating HP Software, Drivers, and BIOS Updates in Vista support document.
My tv has no picure but it has sound. plus, we're able to watch movies on blueray and the picture shows on the tv.
sounds like input problems, if its working with your BR hit the source or input button on your remote and toggle the inputs until you find your cable input its probably going to be hdmi or component
I have a panasonic Viera and I'd like to play my computer through it. The computer picture works fine through a converter to the HDMI cable input but how do I get sound? I need a separate cable from the...
does your computer graphics card have a hdmi output on it? i had a same problem the coverter input will not let sound though it u would need a hdmi output from the computer or need to connect a separated sound output as the form of speakers from the computer itself, i mite be a problems with drives, try updating the graphics card drives. this mite solve the problem as well. hope this helps
Why does my hp pavillion 9700 not have HDMI input?
Are you sure you mean an input? If it's a laptop, it shouldn't have any video inputs. The pavilion 9700 has the same shell as a few other pavilions, but the 9700 was never designed with an HDMI port.
How can i watch movies from computer to my tv
You probably need to get a composite video output card for your computer. Actually, I've seen many cards that have both a composite video output AND a DVI output port on 1 card. The DVI output will give you a noticeably sharper picture than composite video, but you need to check if your TV has a DVI or HDMI input. (If it was manufactured after 2000, it probably does.) If you TV was manufactured after 2006, it probably has 1 or more HDMI inputs instead of DVI. You can buy a DVI to HDMI converter cable. That takes care of the picture; to get sound to the TV, you will need to connect separate sound cables to your TV. Your computer needs to have a line-level output jack on it's sound card, and you will need to get an adapter cable (from Radio Shack) to convert the stereo mini-plug to 2 RCA type plugs to plug into your TV. And that should do it!
1helpful
No longer getting video feed through Home Theatre receiver
HDMI ports 5 and 6 on the back of tv no longer are working. (We had a series of thunder storms so don't know if that is how they got damaged or if it was something else) but moved HDMI input cable to HDMI port 4 on tv and everything is working again. Service call placed for warranty service on tv to repair bad ports.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
