SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker. Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: Fisher and Paykel N500B fridge freezer. Freezer not freezing
The evaporator coil behind the cover on the back
wall inside the freezer will ice up under normal conditions. Every 8 to 10
hours for around 20 minutes the defrost timer (or in most newer models the electronic
adaptive defrost control) will turn the defrost heater on to
melt the built up ice. There is a defrost thermostat which prevents the heater from
overheating the freezer by breaking the heater circuit when the temp reaches
close to 32 degrees F. The entire cooling system shuts off during the defrost
cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to
build up until the air can’t flow over the coil to circulate the cold air
through the freezer and into the fridge. The temperature change in the fridge
is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from
coming on OR it won’t turn the heater off when it gets too warm. It is clamped
to the evaporator coil at the top to sense the temp. If it appears to be
misshapen it is bad.
With an ohm meter it should show continuity when
cold and none when warm.
You can also bypass the thermostat to see if the
heater comes on then. If it does then you know the thermostat is bad and needs
replaced.
The defrost heater is
located on the evaporator. It is in a tube which is at the bottom and can also
go up the sides of the evaporator. On some types you can see a burnt spot if
it’s bad. With an ohm meter it should show continuity from end to end when
disconnected from the wiring in the freezer. You can also test the wiring for
voltage when it’s in the defrost mode.
If
you have a defrost
timer you
can test it. It can be located under the fridge behind the kick panel on the
front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts
down. The heater should now come on. If it does, replace the timer because that
means the timer is not running. If it
doesn't, check the heater and defrost thermostat. Turn the timer again till
everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer,
replace it if the heater and thermostat test good. It is located in the fridge
with the controls in some models and on the back in others.
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
