Televison & Video Logo
A
Anonymous Posted on Dec 25, 2017
Where can I get a square shaped tv rectangular won't fit into my tv cabinet.
Have tv cabinet but all tv are either to wide fir cabinet and the height is to short and looks ridiculous
Level 3:
Top Expert:
  • Televison & ... Master 76,851 Answers
  • Posted on Dec 25, 2017
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15007163
Points
237762
TV with such dimensions are not available now.
Testimonial: "Thanks for the info."
5 Related Answers
Anonymous
  • 1847 Answers
  • Posted on Jun 17, 2008
SOURCE: Wide Screen
For free sony support go the link choose the produce and chat for free
http://esupport.sony.com/US/perl/support-contacts.pl
Thanks for using fixya. Hope this solution may have helped you.
Anonymous
  • Posted on Feb 16, 2009
SOURCE: spacemaker microwave
What I did was get a shorter cabinet and put it in most suppliers have the same models unless handmade.
Anonymous
  • Posted on Apr 28, 2009
SOURCE: Hannspree HF229H monitor and Windows XP. Images stretch to fit.
I had this same issue.
Go into the monitors menu, go down to "Image Settings", go to "HDMI Mode", select "PC Mode"
Hope this fixes it for you. It worked for me.
Anonymous
  • Posted on Dec 19, 2009
SOURCE: the cartridge keeps getting jammed on the left
I will replace the printer. There are so many on sale now, I'm not going to waste money trying to fix it when I can get a new one for what it would cost to fix it.
gdcroft
  • 192 Answers
  • Posted on Feb 23, 2011
SOURCE: you are framing a rectangular
If we assume the width of the frame is X. Then the one dimension of the framed picture will be 2X + 20 and the other dimension of the picture will be 2X + 34. We know the total area of the framed picture should be 640 in^2. Therefore:
(2X + 10) * (2X + 34) = 640
If you multiply this out you get:
4X^2 + 88X + 340 = 640
Subtract 640 from both sides:
4X^2 + 88X - 300 = 0
Divide both sides by 4:
X^2 + 22X - 75 = 0
Use the quadratic equation to solve for X, with A=1, B=22, C=75
X = [-22 +/- sqr(22^2-4*(-75)] /2
This reduces to:
(-22 +/- 48) / 2
The negative solution doesn't make sense in this case. Therefore: X = (-22 + 28) /2 = 6/3 = 3
Therefore the width of the frame should be 3 inches.
4answers
IF LENGTH and WIDTH are given How to find Hight
Never. Even if it a regular shape.
Replacing 185sq ft. Of a concrete block ( 8" x 16 ")wall ...how much block that cost $1.22 ea. Would cost?
If you are working this as a simple math problem, here is the solution. Each block is 8" x 16", which is an area of 128 square inches. A square foot is 144 square inches (12 x 12). Thus 185 square feet equals 185 x 144 or 26640 square inches. TO determine the number of blocks required, we divide the block size in square inches into the total area 26640/128 = 208.125. Thus, it would take 209 blocks to do the job. 209 blocks at $1.22 each = $254.98.
Now, if you are REALLY doing this job and need an accurate cost, you need to specify what the actual height and width of the area is to properly determine the number of blocks because 185 square feet can be any rectangular shape and may not come out to an even block height or width. Thus, the cost may vary considerably.
1helpful
Why are the movies half screen?
Movies that are created for "Wide Screen" viewing show up in letterbox on your TV. If you go to a theatre you notice it is a big rectangle. To be able to fit all of the widescreen movie on a TV it has to make the height smaller.
Because many people want to see the "complete" Movie, the "Letterbox Format" came about. I do NOT know what the word "Letterbox" actually means, or how that term was chosen. To get the complete Rectangle into that Square, they discovered that they could shrink the entire rectangle to fit that square. Meaning, what used to take 2 inches on your screen, now may only take 1.75 inches. Now a problem arrose. When you shrink the WIDTH to fit your dinky Square of a TV, the HEIGHT also has to be shrunk along with it, or else you're stretching the image as if it was on silly-putty ("Compression"). When the image was shrunk to fit the TV Screen, they were left with a gap at the top and bottom of the screen. So they simply fill it in with "Black". I guess the only alternative was to leave it snowy.
There are two black boxes on each side of my tv screen. How do i get rid of these boxes?
Watch some HD or other 16:9 programming. If you have pillarboxes on the sides it is likely that you are watching a 4:3 program that doesn't fit your TV's screen. When people upgrade from a "regular" TV to a "widescreen" model they changed the shape of the TV but didn't change the shape of 60+ years of TV programming, the only ways to force the "square peg" to fit the "rectangular hole" is to either chop off the top and bottom of the image or to stretch it. I highly recommend against either of these as "Stretch-O-Vision" is just wrong because it makes people look fat and turns car tires and other circles into short fat ovals.
How to get an undistorted picture without cropping. This is an Olevia, and it is not listed below.
I assume you have a wide screen tv? most TV show are broadcast in a square (4:3) format, on a wide screen television the screen is rectangular, so to fit the square picture on the rectangle screen you have to either crop the top and bottom, or stretch and distort the image. the only real solutions are either to watch everything in the 4:3 format (leaving the sides of your screen blank), or subscribe to HD which will broadcast most programs in a wide screen format with out distortion.
3helpful
My vizio is stuck in wide mode! Won't let me change it
Stuck in WIDE? Me too. Based on the info below, from VIZIO support website, I think the TV defaults and locks on WIDE if you use an HDMI connection. You have to interpret the language a little bit, but he last sentence seems to imply that the TV automitically displays WIDE.
Aspect Ratio Aspect ratio refers to the images height vs. the images width. The current industry standards for this are 4:3 which square and 16:9 which is more of a horizontal rectangle shape. Most all television broadcasts are 4:3 except for high definition broadcasts. Due to the resolutions required for high definition it will always be broadcast in 16:9.
I want to know what type of cable wire do you need to hook up for HDTV and where you hook it up at on the TV
HD can come from two types of cables. A RF cable, normally it is a RG 6 or maybe a RG 59 coax cable. A HDMI cable is the other method of obtaining HD on your HDTV. A HDMI cable has a rectangular shape with small pins, its about 1/2 inch wide by 1/8 inch in height. The RF connector is about 1/4 in circular. A HD signal can come from a cable box or it can come from a DVD or Blue Ray player. Google these type of cables and look on your TV for the connectors.
Over The Range Microwave new models too tall need under 15 in hig
cut the cabinet off. a cabinet maker can do it and you can tell if they ar good
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
