SOURCE: reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
SOURCE: Hello, I have a 99
Sounds like you've got it together correctly. There is no washer between the brake caliper bracket and the swingarm. You can put the axle in from either direction. We usually put them in from the left side so that we no longer have to remove a muffler to remove the rear wheel. The nut is now on that side. Just make sure the wheel turns smoothly and the brakes work correctly before taking in out on the road. If you hear a chirping noise when you shift gears, your rear belt is too loose.
Good luck
Steve
