Question about Royal Office Equipment & Supplies
Bobber on 1937 royal quiet typewriter does not go up and down to catch ink on spool. I can manually move it, seems like the piece is not catching on the undercarriage
  • 482 Answers
Make sure the ribbon selector lever is in the black position not white if that is not the trouble you may ned a repair person
Posted on Feb 11, 2018
2 Suggested Answers
6ya staff
SOURCE:
squipps
Mike Wheeler
  • 204 Answers
SOURCE: the ribbon wont advance
The ribbon drive on this model are gear driven..a .may be off, a loose set screw on one of the gears..the ribbon may be the wrong one or it has a ribbon reverse lever on the side of the machine, this should be free of binds.
Hope this helps........
Squipps
Posted on Oct 08, 2009
The needle wont stayed treadedwhile sewing. I have changed out the needle and changed out the thread and it keeps unthereading while sewing the bobber is working just wont stay threaded threw the neddle
My trouble shooting suggestions are:
check that the thread is in the thread take up lever eye correctly
Is the top tension set too tight, ie should be on 5
Is the thread catching somewhere in the thread path?
Is it catching on the thread spool itself, sometimes they have a little notch cut in the top edge to hold the thread tail but it could be getting caught in there during sewing. If so, turn thread spool up the other way or use a mushroom cap on top to hold the thread off the spool top edge.
just go through the top threading path checking thread is into all thread eyes correctly and not catching on anything and that it is threaded correctly, it should be one of the above causing this.
Jul 10, 2011 | Brother Sewing Machines
The ivory colored plastic turning knob on the right side (doubt it matters) that turns the barrel so you can insert paper (you can still turn it without, there's a small visible circular piece of steel...
Checked out eBay...
Right here in Sun City California... for PARTS
or REPAIR... (ONE of about 70 machines available)..
VINTAGE ROYAL QUIET DELUXE PORTABLE TYPEWRITER FOR PARTS REPAIR MADE IN...
Being a collector of old car parts (myself) if figure
there were plenty of collectors of Royal typewrters...
Sure enough..!! (hope this inspires).
Carnac the Magnificent
Jan 09, 2018 | Royal Quiet De Luxe Portable Typewrite...
I have a circa 1940's-50's Royal Desktop Typewriter. The ribbon that was already on it was rather worn and severely faded so I bought new ribbon for it. The only available ribbon was a red-black silk inked...
You have the ribbon on wrong. The ribbon dosen't feed off the spool but take up onto the spool. install the ribbon so that the moving spool is taking up the ribbon.
DickyO
Oct 16, 2010 | Royal MS 25 Typewriter
The ribbon wont advance
Squipps
Oct 07, 2009 | Royal Office Equipment & Supplies
Switch functions on royal manual
Probably are the touch control if it is a plus or minus..or maybe the ribbon selector for color blk or red also white (stencil) or may be touch control for the keys.
Sep 13, 2009 | Royal Office Equipment & Supplies
Margin settings
You have to hold the magic margin button down while you move the carriage all the way to the left, then release the margin button. Then repeat for thr right margin. Hold the right magic margin button down while moving the carriage all the way to the right, then release the margin button.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Sep 05, 2009 | Office Equipment & Supplies
Carriage won't advance with space or letters.
You will have to take this in for service. Bad escapement
Jun 26, 2009 | Royal Office Equipment & Supplies
Smith Corona Classic 12 ribbon won't stay in place
Okay...i had the same problem when I replaced the original ribbon that came with my Classic 12. I think it was the ribbon that came with the typewriter.
Anyway, on the ribbon carrier, there are two sets of metal prongs on top of one another. If you get the ribbon behind both of them, it will pop up and not go back down or won't come up at all.
You have to get the ribbon between the two sets of prongs. There's isn't much room and you have to kind of pull the bottom of the ribbon taught and slide it down from the top.
It isn't easy the first time, but after you get it, you won't forget.
As for your ribbon not feeding...take the spools out and make sure the pegs that go into the holes in the spools are rotating when you type. This is what moves the spools. Then make sure you're getting the pegs in the hols when you put the spools back in.
Also, make sure the ribbon isn't twisted anywhere and that it's threaded correctly. Both spools should look identical with the ribbon coming out of the top toward the carrier.
To ensure you have the correct ribbon, got to the Office Depot online store and do a search for Smith Corona Classic 12 and you will get a pretty generic, double-black ribbon that fits and works perfectly...and is so soaked in ink you can reuse each side three times. I don't recall the brand name, but the box is grey with red lettering.
Apr 16, 2009 | Smith Corona Office Equipment & Supplies
Royal ribbon glitch
watch the ribbon spools as you type to see if they are turning.
May 21, 2008 | Royal Office Equipment & Supplies
41 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Marvin
Marvin
Adorjani Laszlo
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
