It was getting overly hot before the fuse first blew out, someone mentioned a magnetron?
SOURCE: Microwave keeps blowing fuse
If it went dead almost immediately after pressing the Start pad, that\'s usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that\'s usually a failing high-voltage transformer.
Here are some links with info on part testing:
http://www.microtechfactoryservice.com/cap_test.html
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
Please write back with your brand and model number if you need further help.
We\'re happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: top of over-the-range microwave hot to touch; normal?
A little over 100F is hotter than most folks can stand to touch, so it may not be seriously hot.
But if you're concerned, you might see if your dealer will let you test another one or a similar model at the store to see if it also gets that hot.
Otherwise, you can return it to be safe or you can contact Panasonic consumer electronics support here or at 1-800-211-7262 to ask them about it.
We're
happy to help you with free advice and we'd appreciate your
SOURCE: keeps blowing fuses
This problem is just like my own microwave, replace the shorted HV capacitor
SOURCE: Ewave over the stove microwave fuse blows when I
The light is the only thing that comes on when you open door. You either have a shorted door switch (Micro switch) or a shorted bulb. You have either a shorted bulb or bad socket. From my experience, it's the bulb. Just because it may seem to start to come on when you open the door, it's most likely bad. At least it not expensive.
Please rate solution
Testimonial: "Thanks, yes the light comes on for a second then fuse blows. I'll replace it, thanks!"
