SOURCE: bosch washing machine won't drain and the door won't open.
Sounds like you have a blocked pump.To empty the machine manually lower the drain hose into a bowl or bucket.Once emptied the door should open.On most modern machines there will be a filter behind the kick plate at bottom front of machine, Check this for any foreign objects then try a spin before putting on again.If problem persists come for further options.
SOURCE: Bosch WFF1800 - not spinning
HI,
move the kicking plate on the front-bottom of the machine. You will see
o circular lid there, turn it on anti-clockvise to open. All of the
water blocked will come from there, be careful. Look carefully that
there are some objects blocking the water draining. Then turn on the
machine on draining programme, the plastic rotor should turn fastly
when the machine is on. If it is not running, change the pump motor. If
it is running, but machine is not draining again you can understand
that there is an objeck stuck on the hose between drum and pump motor.
Lay down the machine on its rear facade, you will see a large and black
hose between drum and pump motor. When you remove it, you will see that
there is something that blocks water running.
thank you for using fixya,rate my answer,
vijay
SOURCE: my Bosch classic 1200 express washing machine wont drain or spin
Possibly a blocked filter or pump.
Ths filter should be at the bottom right front of washer, sometimes behind a removeable cover at the bottom of washer.
To clean it, unscrew anti-clockwise, remove and clean.
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
SOURCE: sud message Bosch washing machine
ur using too much soap rinse and spin and use less soapwhen u wash
Testimonial: "thanks-- how do you know how much soap is enough?"
