SOURCE: Gas fireplace pilot flame won't stay lit.
Hi , you can try and pull the panel on the bottom of fireplace out and check the adapter in fireplace. Sometimes they go bad. When you open in also check to see if there is an adapter plugged in and a option to use the battery operated function. If this goes bad the pilot will not stay lit.
SOURCE: I HAVE A DESA LP VENTLESS FIREPLACE AND THE PILOT
the heater makes use of a millivolt generator which generates a small dc voltage (500-750mv) that is applied to the pilot valve of your main gas valve. when you light your pilot, the flame bathes the generator with a flame. after a delay you release the pilot button. if the generator is working, the pilot valve will stay lit. if the generator is not working the flame will go out as soon as you release the pilot button. change the generator.
SOURCE: pilot light flame is mostly yellow. LP gas
Thr thing you need to do is take the pilot assembly all apart and blow the dust and dirt out of it.
After burning for many, many hours the air that is move up through the pilot assembly leaves dust and dirt which plugs off a bit of the air and makes the flame run rich. Meaning that it does not get enough air mixed in for complete combustion.
When you clean it you will see the dirt and dust com out of it.
Reassemble carefully just as you took it apart and it will be back to working great again!!
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Testimonial: "thanks that was it. "
SOURCE: have a vent free lp wall mounted heater.40 lp tank
Too much gas pressure. Are you sure that this is a LP heater and not a Natural gas heater? Is the regulator you have rated under 1/2 pound pressure? Try to throttle down the shutoff on the tank to see if pilot gets better. If so, you have a pressure issue. Gas you adjust the pilot gas valve?
SOURCE: After the pilot lights, the
This is most definately a bad thermocouple. Very eaasy to replace.
