SOURCE: How to replace lockdown pin DW708 12" sliding compound mitre saw
you are going to have to drill the inside pin out. be sure to center punch and drill a pilot hole. hope this helps
SOURCE: New or used motor for a Craftsman 10" table saw
You can try Sears but they can be a bit pricey. I use to send out motors for a factory I worked in to a rebuilder who would even do new windings. Check in your area for a rebuilder, As for the replacement being a Sears unit they may have a similar motor in stock. Good luck.
SOURCE: i need a wiring diagram for the switch and circuit
go here for owners manual. Or use contact to request wiring diagram:
http://www.hitachipowertools.ca/en/Products?cat=37&pid=183
SOURCE: In need a new on/off switch for a Tradesman 10" Table Saw, Model 8030, Serial 000864
any 20 amp toggle switch will work.
Sears no longer sells repair parts for this motor, only the whole motor as a replacement part, and it is $140.00, but you can buy replacement bearings from drillspot.com the bearing needed is an Enduro 6200 zz c3
