Hi Ginny,
Try these steps:
- remove the batteries
- press and hold the power button on the remote for 30 seconds while batteries are out
- insert the batteried back
Please don't think me rude or ignorant, because I am far from it, but possibly your batteries are incorrectly fitted maybe? Or it could be complete remote control malfunction, you can buy universal remotes quite cheaply but take your tv's make/model/serial number with you to check its comparability, hope this helps
SOURCE: need remote control code for 32" X2GEN tv
Good luck. I have the same issue. No codes are available for the X2Gen. To make matters worse, it appears to use a non-standard frequency for the carrier signal, maening that other remotes won't work with the TV.
I purchased a learning remote, thinking I would just "teach" it the codes directly from the X2Gen TV remote. This didn't work either.
There appears to be no way to use any remote other than the one supplied with the TV. Whatever you do, don't lose it!
SOURCE: remote code
Use the search function, but don't give up. It takes about 20 minutes to find the correct code.
Here are the instructions
SOURCE: I have a Technika 32'' TV/DVD
my tv remote wont work i bought a new one but it requires you to enter a code and i dont have it. the tv is a technika 32-601 the codes 1484,0193,0363 dont work anyone know the right code
SOURCE: remote control code for 32 inch lcd EMERSON TV
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
SOURCE: my dynex remote control for 32 inch flat screen
I just called Dynex because I had the same problem. Remove the batteries and press the power button and hold it down for 15-20 seconds, put the batteries back in and try to power on and power off, change channels, etc... if so the remote is fine. The guy told me that sometimes when you need to replace the batteries you also have to re-set the remote control.
