SOURCE: Norelco model 5885 XL Battery replacments
I just installed two brand new Eneloop cells and it will only charge up to 35 minutes on the display (I had been able to get up to 52 minutes with the original NI-CAD's). I also discovered that it would not recognize the capactiy on the minute meter until I drained the batteries and recharged the unit. When I went to drain the batteries they ran for 2 hours and 15 minutes!!! But again the display only shows 35 minutes right now after an hour charge when it says FULL. I'll leave it on the charger and see what happens. I used a pair of needle nose pliers and "rolled" the metal tabs off the NI-CAD's. Snapped the one on the negative side but got the positive side off clean. I couldn't get the strips to solder back to the new Eneloop batteries so I had to use electrical tape which seems to be holding fine. The battery holder holds the positive and negative terminals against the old tabs just fine. Also I learned that if you hold the power button on long enough it will cycle through a test function. It will go to zero minutes and all the way up to 35, then turn on and go back to zero stopping at the appropriate cleaning cycle times (takes about 40 seconds to do the test so don't touch the power button until it's done). Not sure if the batteries will still go 2 hours and 15 minutes after being charged in the shaver, but they do when chaqrged outside the shaver. Just my two cents!
SOURCE: Milwaukee 1/2 lithium ion 18v drill not working
I have the same problem and its about a year old too.
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help [email protected]
thanks
SOURCE: I have a Uniden BC60XLT-1 Scanner it has its 12v
The two battery types are completely interchangeable. Set the charger for NiCd and the NiMH will charge faster and last longer than the NiCds did.
Testimonial: "Thanks BillB-SA I just didnt want to mess up my scanner and I wasnt sure You helped me out and I thank you."
