Archos 5 MP3 Player Logo
Posted on Jul 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I CAN RECORD FROM MY TV BUT I CANT GET MY ARCHOS 5 TO SHOW ON THE TV ,WHEN I PLUG MY ARCHOS INTO THE DVR STATION THE OPTION TO SET IT UP FOR TV DOES NOT COME UP . I WOULD BE VERY GREAT FULL FOR ANY HELP, THANK YOU , TONY
  • tonyboucher3 Aug 24, 2009
    THANK YOU I HAVE IT SOLVED NOW BUT I HAD TO RESET MY ARCHOS AND ALL THE BUILT IN WALLPAPER AND MY PLUG INNS HAVE BEEN LOST . TONY
  • Anonymous May 11, 2010
    How do you have the archos hooked to your tv set? You have tell the archos what type of tv connction you have to set up the tv wizard
Anonymous
Level 2:
  • Expert 61 Answers
  • Posted on Sep 14, 2009
Anonymous
Expert
Level 2:
Answers
61
Questions
Helped
58125
Points
121
You should swtch your TV to the video mode on to the video output chosen for the device. Check the video connecion type by following the output cables from the DVR station or charging dock to to TV. it could be video 1, 2, 3 HDMI, Color stream HD1 , Color stream HD 2, by scrolling down on the video mode list you should get the picture on on of them with correct video mode. or like i was saying follow the output cable from dvr station to Tv to see which video mode it was connected.
I have an archos 404. i have a dvr station as well. How do i get my movies from my archos to play on my tv?
The Archos 404 attaches to the TV using either a DVR Station or a special AV cable. The AV cable uses a special small audio-style mini plug on one end to the standard red, white and yellow composite video connectors on the other.The docking station can record from and playback to the TV. The DVR Station 5 uses S-Video and red/white RCA plugs for connection to the TV. Optionally you can use the yellow/red/white composite connections instead. Hook it up similarly to a VCR, input from the cable box to the input of the DVR Station and output of the DVR Station to the input of the TV.
http://www.archos.com/support/download/manuals/connection_guide_dvr_station_v1.1.pdf
http://www.archos.com/support/support_tech/manuals.html?country=us&lang=en
No sound when I record from my TV
Are you using the DVR Station Gen 5 or DVR Travel Adapter?
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Trying to connect Archs DVR snap on to LCD TV and record
As far as i am aware you cannot record directly from the tv using a dvr snap on to record from the tv you would need the dvr station.
Can I pre record on the archos 605 wi fi 30gb
You have posed a very good question with a very complicated answer. There are two things you MUST have in order to do what you are asking:
1) Your "docking station" cannot be the Archos mini-dock, b/c the mini dock has inputs only. Your docking station must be the Archos DVR Station - Gen 5.
2) You have to have a digital cable box, FIOS, or digital satellite box.
You will be recording from your cable, satellite, or FIOS box instead of directly from your TV. Hook the red, white, and yellow cable from one of the red, white and yellow outputs of your cable/sat/FIOS box to the specialized adapter of the DVR Station (make sure your Archos 605 is properly docked inside). Here is a link to the connection guide if you don't have it:
Once the connection is set up, you must follow the exact directions printed on pp.11-15 of the DVR Station user manual - it will require downloading several pieces of software. My only reccomendation is that you make sure that the Archos 605 is fully charged before proceeding, b/c if it loses power during the process, you may ruin your mp3 player. Here is a link to the DVR Station user manual:
http://www.archos.com/support/download/manuals/english_user_manual_dvr_station_gen5_v3.pdf
If you have followed the instructions exactly, you will be able to schedule your recordings to your Archos 605.
There are two catches that I noticed with this player - 1 major and one not-so major:
1) Not-so major: Your subscription to the TV guide that enables you to schedule recordings will only be free for 1 year
2) Major: The DVR Station forces you to choose between an NTSC and a PAL format when choosing a TV standard for playback. PAL is only for Europe, so never select it under any circumstances. NTSC is shutting down on February 17, 2009 - in a little more than a month. After that time, you may not be able to display the recordings that you have made to your TV itself.
-Tha Mp3 Doctor
2helpful
CAN I PRE RECORD PROGRAMMES ON THE 605 WI FI 30GB
Archos 605 Wifi w/ Archos DVR Station Gen 5
-Tha Mp3 Doctor
Archos DVR Station & 605 wifi PMP
Not sure if this will help you or not, but I have a 404 and was having issues with the scheduler changing the channels for me also. Then I realized that it is a infrared transmitter - the same frequency as a remote I realized what I was doing wrong - Your archos station must be facing the cable box that it is turning on. I had my archos on top of the cable box and it was not working - but when I turned the cable box and the archos station to face each other - so the signal can transfer - it worked just fine. Hope that helps!
Archos 504
Simply said you require a DVR station or Audio/Video travel cable. On the DVR just simply plug in your composite cable from OUT the satellite/cable box or whichever source your recording from to IN on the DVR station. The a/v travel cable is a little easier to hook up. Then just select the VideoCorder icon.
1helpful
3answers
Connect My Archos to my TV
Archos has a site with a video demo on how to connect all leads
Top Archos Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Audio Player and Recorder Expert? Answer questions, earn points and help others
