Photography Logo
C
Caroline Foulger Posted on Jan 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My tripod points slightly downwards when the camera is attached and I don’t seem able to fix it. The spirit level says it is straight.
  • 2 more comments
  • Tony Parsons
    Tony Parsons Jan 01, 2018
    Use a hot-shoe mounted spirit level.
  • Caroline Foulger
    Caroline Foulger Jan 02, 2018
    Sunpak 6600dx
  • Tony Parsons
    Tony Parsons Jan 02, 2018
    A Pist*l-grip tripod is frequently unable to support heavy equipment, as it relies on a spring-loaded friction plate to retain position. Swapping the head for a traditional variety might improve things.
  • ogerfire Jan 10, 2018
    We used to use sand bags hung from the inside apex of the tripod to compensate for too heavy equipment. Depends what you hangit from.
Louis Korkames
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 28 Answers
  • Posted on Jan 01, 2018
Louis Korkames
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
28
Questions
0
Helped
4615
Points
98
Do you have a heavy lens on the camera body? You might have to compensate for tilt by adjusting tripod. Heavier duty tripod might help.
Parshiv Luthra
Level 3:
Master:
  • Master 395 Answers
  • Posted on Jan 02, 2018
Parshiv Luthra
Master
Level 3:
Master:
Answers
395
Questions
Helped
86313
Points
1069
What tripod do you have?
5 Related Answers
Anonymous
  • Posted on Oct 02, 2007
SOURCE: Tripod
I have the same problem. Can't believe I can't find the shoe, but the tripod is worthless without it. If you get an answer, please email it to [email protected]. I'd GREATLY appreciate it!
Anonymous
  • Posted on Jan 31, 2008
SOURCE: attaching camera to tripod
Go to:
www.tripodquickrelease.com/Vivitar_Quick_Releases.htm
There is a list to select from you'll find it and it will cost $15.99
Good Luck,
Santa
Anonymous
  • 24 Answers
  • Posted on Jan 30, 2009
SOURCE: Vivatar Tripod V3000 Camera Attachment Adapter for Nikon D80
Try www.tripodquickrelease.com They have that exact model listed and the plate sells for $16.99
Anonymous
  • 9 Answers
  • Posted on Mar 20, 2009
SOURCE: Removing Tripod from Camera
Here is a diagram on how to remove the camera from the tripod then remove locking plate from camera
Anonymous
  • 3006 Answers
  • Posted on Aug 11, 2009
SOURCE: I bought a used camera tripod that does not fit my camera
Your tripod is a K-Mart brand item and it will fit any camera but it's clearly missing the quick-release foot which most tripods have these days. This part screws to the bottom of the camera and enables the camera to be quickly attached and removed from the tripod.
Unfortunately there is no standard foot shared between manufacturers and most tripod manufacturers don't even have a standard design foot which fits all models in their range.
You can still order a replacement foot from:-
http://tripodquickrelease.com/Focal_Quick_Releases.htm
But at US$18.99 it may be cheaper to buy a new tripod!
I hope that you appreciate the time which I've taken to research and answer your question and ask only that you return the favour by rating my answer.
Testimonial: "Great response and fast too. Thank you."
Benro A2682T Travel Angel 2 Aluminium Tripod instruction manual
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
Alternatively the manufacturer's support website may be able to help you.
Not really sure why you need a manual, anyway - most tripods are similar : legs set to correct height, pointing downwards, splayed for rigidity, then camera goes on top, using the head to point it in the correct direction.
Konig tripod - can't get quick release plate off I can't work out how to get the quick release plate off my "Konig Professional Tripod For Photo and Video Cameras". I've tried unscrewing the two screws...
I had the same problem a few minutes ago. You don't need to unscrew any of the fixing but make sure the larger silver bolt is not tight. The instructions are: 1. Use your thumb to push down the silver lever to the left of the spirit level. 2. Whilst holding this lever down slide the top of the top of the quick release mechanism to the right (looking at the spirit level) and it should come off. Once you do it you'll know how much force to apply in future. If this doesn't work try loosening the large bolt a little more. You can safely remove it, but remember to replace it as it is used for locking the quick release. Note that the locking only starts after this bolt is turned 2-3 times, before this the quick release should work fine.
Sep 03, 2017 • Photography
How do you level your camera inclination (left and right) in order to level camera when tripod is on unlevel ground?
Hotshoe mounted spirit level ($10 -$20 USD) or Bogen distibutes a head leveler, similar to those found on surveying instruments.Approx $100USD)
Once the camera is attached to the tripod, how do I remove the plate with camera still on it?
There should be a release button or lever at the back or bottom of the top plate to release the quick release
1helpful
On My CST berger 32X automatic level unable to hold vial bubble center as instrument is rotated 180 degrees - instructions say to use vial adjustment screws to correct this problem...this does not seem to...
take a topedo level and get the tripod base as level as possible. attach your level to the tripod. put all screws in the middle and level it. turn 180 degrees, level it. turn 180 and check. if withing the bubble, turn 90 degrees and level. turn 180 and so on and so forth. the adjustments should be slight from turn to turn. make sure the feet are secured firmly in the ground. If this does not level the automatic level, it needs sent in for calibration. I dont know the web address but I hope this helps
2helpful
2answers
Reserve Knob what is the correct position for riding?
You should see a small arrow on the knob. that should point downwards.
10helpful
2answers
2helpful
Need manual for kodak Gear Tripod 60'' or instructions about it's
Look at the bottom of your camera and you should see a hole where a screw would screw into. That should be the screw on the top of your tripod.
Bogen Manfrotto 3047 head
Dear spiderinkart,
To get the camera to secure properly to the release plate make sure that the bolt is screwed entirely into the camera bottom and then there should be a larger knob that rotates around the bolt that tightens down to the camera body. What I do to get a really tight fit is point the arrow on the bottom of the release plate labeled lens (that arrow when properly mounted should be pointed towards the front of the lens) to a 45 degree angle to the left of the lens, then I snug down the knob, and then I grab the release plate and turn it until the lens arrow is aligned with the front of the lens. As far as quick releaseing the camera from the legs when secured on the release plate you should be able to pull the lever away from the head and it should simply release the camera with the plate attached.
Sincerely,
Agent Allan
Go Ahead. Use Us.
Top Photography Experts
Tony Parsons
Tony Parsons
ADMIN Andrew
ADMIN Andrew
Are you a Photography Expert? Answer questions, earn points and help others
