Question about IBM Office Equipment & Supplies
IBM WW 5 line space l, 1 1/2, 2 Blink continually. What does this mean. I used to work on them but have forgot. Thanks Jim
  • 482 Answers
Beeps three times and line space selector lights flash usually means you need new batteries
Posted on Feb 11, 2018
6ya staff
SOURCE:
Dick O Reilly
  • 3594 Answers
SOURCE: How do you replace the batteries on an IBM Wheelwriter 3
If this a WW3 there are no batteries, ckeck the keyboard connectors, if they seem OK take it back
DickyO
Posted on Dec 19, 2008
Dick O Reilly
  • 3594 Answers
SOURCE: IBM Personal Wheelwriter 2 by Lexmark not working
It sounds like the keyboard is going bad see my tip under WW1000.
DickyO
Posted on Jun 25, 2009
Dick O Reilly
  • 3594 Answers
SOURCE: IBM Wheelwriter 5 nonresponsive, line spacing lights flashing
A lot of possibilities Which lights, beeps, how many? Check for debris in and around the printwheel, look for any obstructions under the carrier, put a few drops of oil on the silver shaft the carrier ride on.
Good Luck
DickyO
Posted on Jul 02, 2009
Dick O Reilly
  • 3594 Answers
SOURCE: IBM Wheelwriter 5. Beeps once when turned on,
Try reinserting the printwheel, check for debris in the printwheel area.
DickyO
Posted on Jul 06, 2009
Dick O Reilly
  • 3594 Answers
SOURCE: When I turn on my wheelwriter 1000 it beeps 5
First be sure the printwheel is installed properly, and look for debris in that area. Put some light oil on the silver shaft that the carrier slides on (WD40 is good).
DickyO
Posted on Jul 31, 2009
How to solve a problem with an IBM Wheelwriter 10 Series ll Model 6783
It is most likely a bad keyboard. You can try my fix under WW1000 or contact Geo. Beyers Co. for a rebuild.
DickyO
Feb 28, 2013 | Swintec Ibm Wheelwriter 10 Series Ii...
I have an IBm Wheelwriter 5 typrwriter. When I turn it on the line space lights blink and I cannot type or get the casette to move at all.
How many beeps? Which Lights? Blinking together or sequentially? These will help to determine the problem.
DickyO
Aug 04, 2011 | IBM Wheelwriter 6 Typewriter
Wieght watchers scale WW-87 What does P-1 one
P-1 means "Person 1". It has spaces for 10 entries.
Jun 17, 2011 | Conair Weight Watchers WW-87 Body Fat...
I have a IBM Personal Wheelwriter 2 by Lexmark and when you turn it on it beeps twice and then the single and double space lines light up and stay on but the it will do nothing else. (It's like it is...
Probably the key board is bad you can try my tip under WW 1000 or contact Geo. Beters Co.
@ 800-392-8085 for a key board rebuild. Tell them O'Reilly sent you.
DickyO
Apr 07, 2011 | IBM Wheelwriter 30 Typewriter
IBM LEXMARK WHEELWRITE 5 TYPEWRITE NOT TYPING
Be sure the print wheel is properly installed and that there is no debris in the P/W area. otherwise you'll need a tech.
DickyO
May 19, 2010 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 1500 Beeps 6 times and then 1, 2 & 3 Lines Spacing Blink? I have already changed the transport motor - Any other suggestions would be most appreciated. Thanks.
Few things to check. Turn the T/W off and be sure the carrier moves back and forth easily, if not look bfor debris in side machine, lube the silver carrier shaft with some WD40. If these fail you are looking at a board or metal debris on or under the board.
DickyO
Aug 25, 2009 | IBM Office Equipment & Supplies
When I turn on my wheelwriter 1000 it beeps 5 times then the #1 and #2 line space lights blink. The keys are frozen as if the typewriter is on off mode. I powered the machine down and unplugged it and...
DickyO
Jul 30, 2009 | IBM Office Equipment & Supplies
DickyO
Jun 24, 2009 | IBM Wheelwriter 30 Typewriter
LED 1, 2, 3 blink machine doesn't work
If it beeps three times then the line space lights blink
1 the batterys are installed incorectly
2 no batterys are installed
3 the batterys are weak or dead
Feb 22, 2008 | Lexmark Wheelwriter 5 Series II Typewriter
219 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
CheckitRight
CheckitRight
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
