Vehicle Parts & Accessories Logo
Mz. Cece 5823 Posted on Jan 02, 2018
Viper 7856v remote is blinking after I start or lock my car. Whats happening
Jaime Paniagua
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 10, 2020
Jaime Paniagua
Contributor
Level 1:
Answers
Questions
0
Helped
6812
Points
When I press unlock nothing happens only all green light are on can someone help me please
John Guest
Level 1:
  • Posted on Nov 15, 2019
John Guest
Contributor
Level 1:
Answers
Questions
0
Helped
6812
Points
ALL of these answers are TOTAL GUESSES! The fact of the matter is that it could be 1 of 5-15 possible things. Anywhere from a shorted sensor to a simple remote reprogram. If you want it FIXED CORRECTLY. Simply take it to whoever installed it(or a dealer near you) and they will have it, not only, taken care of. But they'll probably also explain what happened and other possible problems/glitches & corresponding remedies for the future. Bottom line...you start pressing and holding buttons without actually knowing what you're doing, or what's wrong. You could just cause more significant problems! Like locking yourself out & having to disconnect it! You bought it...enjoy the benefits of "customer service". While it still exists!
5 Related Answers
Anonymous
  • 22 Answers
  • Posted on Dec 04, 2008
SOURCE: the battery was taken out
Put the key in the ignition turn in two clicks. Take the key out hold down the program/valet button on the remote start then hit the unlock button on the remote.
VZW
Rico
  • 3 Answers
  • Posted on Sep 13, 2009
SOURCE: Viper remote stopped working!
First things first. Check the fuse that powers your alarm system. If that seems to be ok then try the next simple option. Open the hood and disconnect the negative battery cable. Then turn the ignition to the start position for approximately three minutes. This will allow for any remaining energy to dissipate from your system. Now you can reconnect the negative cable. *** Before trying your alarm *** turn the ignition on and off 3 times quickly. Make sure you don't start the vehicle. Now you can exit the vehicle and try your alarm. FYI you can always stop at a nearby Best Buy store for additional assistance. They are usually very helpful. Good luck and best regards, Rico...
Anonymous
  • 5 Answers
  • Posted on Oct 09, 2009
SOURCE: i have a viper alarm with remote start the remote
the alarm is in valet mode .open a door press lock unlock lock on the remote and it should take it out of valet mode
Anonymous
  • Posted on Nov 18, 2009
SOURCE: Can you lock the viper 5301 keypad?
Yes.
Press and hold Function (f) for 12 seconds.
Press and hold Lock for 2 seconds
(The keypad will light up)
If the green light by the lock button shows keypad lock on/off (no light).
Press lock- green light comes on.
Press and hold f for 2 seconds
Command entered
Press and hold f or wait 30 seconds for it to time out and the amber light turn off.
Anonymous
  • Posted on Nov 27, 2009
SOURCE: How do I lock my keypad
there is a way to do it in the manual which can be found at www.viper.com/support.... i did it by mistake and now can't figure out how to turn it off
Viper model 7856V problems Car wont start with the remote starter but doors open and close remotely
ThersTHERS ONE IMPORT ANT THING ABOUCAR STARTERS AND THEY ARE SENSITIVE AND VOUNERABLE TO VIBRATION ISSUES DUE TO EXOTIC FIRM SUSPENSION AND UNFORGIVING PAVEMENT, ONE KEY EASY TRICK IS CHECKING THE CONNECTORS (WIRING DIRECTLY ON STARTER) IF NO VISABLE LOOSE NESS -SPRAY SOME WD-40 OR OTHER GOOD QUAILITY INHIBITOR RIGHT ON CONNECTORS . JUST A GOOD QUICK COAT. NOT OVERLY DRENCHED. I WOULD SUSPECT RESPONSE RIGHT AWAY. GOOD-LUCK FRIEND.
Why won't it start vehicle?
[PDF]Responder LE Model 5701 Security and Remote Start ...
xtremetruck.net/file/1101-Viper+5701+Owner's+Guide.pdf
the year, make and model of the vehicle; vehicle license number and vehicleidentification number. All ..... One five-button/2-way Supercode Responder LE RemoteControl. ? .... Disarm. Unlock LED blink for one second with 2 Beeps. Remote. Start..... Long-time Viper system users will notice the following differences:.
Viper LED 2-Way Security + Remote Start System
https://www.viper.com/car/securityremotestart/.../viper-led-2-way-securit...
Viper's elegant new Responder LE transceivers mark a giant leap forward in 21st century vehicle security and remote start, and an evolutionary milestone for the ...
Viper 5901 remote start error fix - YouTube
? 2:38
https://www.youtube.com/watch?v=wsSorAf88nw
Jan 13, 2013 - Uploaded by Power2ThePeopleZ
5901 won't start vehicle; gives an error. ... or even try to open the hood. the door remains locked when you start the car with theviper alarm.
Help With Programming/Pairing Viper Remote - YouTube
? 2:49
https://www.youtube.com/watch?v=cgbQsZuVyt8
Dec 2, 2010 - Uploaded by Paul L
I have a two-way remote from my Viper 5901 system. ... The other car (one in video) has the Viper 5701 system in it. .... and then release 3) press the remote start button 2 times until pairremote is displayed 4)press and old ... I had the same problem that the remote won't pair with the system no matter what.
15964701 Viper 5701 2 way alarm w/ remote start won't
Viper remote start system just installed. When I use the remote to lock the car--there is no longer a chirp noise that confirms I hit the lock key. Thanks, Mary
I don't know which remote starter you have, but I have a Viper 5101. To fix this problem, I started the ignition, then turned it off, leaving the key in the ignition. I pushed the Valet button (it has a blinking blue light, mine is near my rear view mirror) and held it. Then, I pushed it 3 times, then held it down a 4th time. Then, I pressed the lock button once. I pushed the Valet button again to take it out of programming mode, and it worked! I got this sequence of steps from the installation manual online: http://www.scribd.com/doc/45065156/Installation-Viper-5101 Hope that helps!
Just got my viper 5701 yesterday and the auto start on alarm worked perfectly. I woke up this morning and the auto start would not turn motor on. locks worked and everything. Took it back to dealer they...
The buzzing noise and lights blinking 5 times is part of the "Find my Vehicle" feature. This usually happens when/if you press the button too long. It takes a little getting use to, but keep practicing pressing the Remote Start button down for only a second or less... you should be releasing the button almost immediately after you hear it make the confirmation tone (meaning the vehicle has received the signal to start). If this doesn't help out, then you may need to go back and talk to your installer about trouble shooting!
I purchased a avital 4103 remote start kit.i also have a viper 300 esp alarm system installed. my question is can i use the avital remote control to activate the viper alarm and start the car along with...
Avital and viper remotes even though they look the same, they operate at different freqs. Im a retired alarm installer i could never get them to interchange.
2helpful
My Viper 5701 has been flawless but now on locking/unlocking the car no longer "chirps." Everything else still works perfectly such as the flashing lights. The remote also has changed its noise from the...
Check to make sure that the valet is not engaged. The alarm will notify you by having a constant lit light. If the light flashes like it should open a door and check to see that the light blink on and off as if the alarm were triggered. If this happens the your problem is with the siren, just have it replaced.
VIPER 160XVL remote start stopped working
sounds like the unit has lost power. i can't tell you where the relay is located for that device but it may have failed.
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
