Health & Beauty Logo
Dennis Wilsea Posted on Jan 03, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is there a replacement battery for a Panasonic ES365 Wet/dry Razor?
vince
Level 3:
  • Panasonic Master 2,530 Answers
  • Posted on Jan 03, 2018
 vince
Panasonic Master
Level 3:
Answers
2530
Questions
0
Helped
748976
Points
8845
Yup...18 bucks....
https://www.ebay.com/itm/New-Shaver-Battery-for-Panasonic-ES364-ES365-Razor-/181605638343
4 Related Answers
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Dec 07, 2010
SOURCE: I have a Panasonic ES8243
It means it's time to change the head. You will find replacements at shaveroutlet.com. See link below
http://shaveroutlet.com/catalogsearch/result/?q=es8243+foil
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Dec 16, 2010
SOURCE: Where can I find a
Panasonic does not sell the specialized batteries for their shavers. Your best bet would be to purchase one of the models that replaced it. I have included links to two models below. These are very similar to model ES4011 and use the same shaver head as your model
http://shaveroutlet.com/shavers/panasonic-es-rw30s-mens-wet-and-dry-shaver.html
http://shaveroutlet.com/shavers/panasonic-es4026-shaver-with-er416-nose-and-ear-hair-trimmer-p-699.html
Testimonial: "Thank you for the help. Appreciated!"
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Mar 01, 2011
SOURCE: Battery in Panasonic ES8183 wet and dry shaver
A 12 months old wet and dry shaver must have a defective battery after such long period of use.
The battery cell is weak and unable to hold charge.
You sure need a battery replacement. It's not necessary you get a Panasonic battery replacement as long as its the same size, shape and watt. You can get another battery from any electronics accessories store within your vicinity.
All you need do is disassemble the shaver, remove the old battery, use it as a sample for the replacement so that you can get the same battery size, shape etc..
To disassemble the shaver, first, take the shaver outside and use a can of air to clean the shaver. Repeat this at various stages of the dis-assembly, being careful not to lose any parts!
Remove the two screws at the bottom (the end that plugs in to the charger) of the shaver, and remove the bottom cover. Keep track of the two small washers, and a small flat plastic piece, about 10mm square that fits inside of the cover - these keep the unit waterproof.
Open the shaver head, and remove the blade assembly from the white plastic vibrating arm by pulling on it - it will pop off. Undo the two screws on either side of the arm, keeping track of the two small washers under the plate - these will tend to stay in place and stick to the metal plate or the plastic underneath the plate.
Press on the mechanism from the end you first opened, and notice a gap opening up where at the other end, just below the head latch button and hinge. Gently pry open this crack, and work the case apart. Keep the large O-ring that seals the case, and make a note of its orientation so that you can assemble it the same way.
This has been too easy, I know, so there is one headache. I have not figured out how to remove the sliding trimmer assembly. Because of this, I found it was necessary to pry the large black U-shaped plastic clamp from the vibrating arm at the same time you pull the innards out of the case
By now you should have access to the battery, and proceed for the battery replacement.
I hope you understand the above.
Good luck.
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Aug 04, 2011
SOURCE: LOST DIRECTIIONS FOR RECHARGING PANASONIC
You will find the instruction manual at shaveroutlet.com. See link below. When page opens, click the 'user manual' link near the 'add to cart' button
http://shaveroutlet.com/women-s/panasonic-es2207-close-curves-rechargeable-wet-and-dry-ladies-shaver.html
I need an adaptor for shaver es365 but cannot find re3-64, si there any other model I can use? It’s a Panasonic
Most of this adapters are similar. Just see how the connector pin looks like, the power rating and finally see how the power pin is marked.
Wet/ dry panasonic es2207 razor quit working
If you've had the shaver for a few years or more, the battery is probably dead. Because the batteries are specialized and not available, replacing the unit may be in order.
SERIAL # ON PANASONIC WET/DRY RAZOR
If you are trying to located a serial number, it may be on the box that the razor came in.
LOST DIRECTIIONS FOR RECHARGING PANASONIC WET/DRY WOMEN'S ELECTRIC RAZOR ES2207. Thanks!
1helpful
Where can I find a replacement battery for a Panasonic ES4011 wet/dry shaver? I have looked everywhere. THANKS!
1helpful
Electric razor won't charge
I've had two different charging issues with my wet-dry electrics over the years. The first is the same one as here: The battery croaks and you need to replace it. I take the old one apart, save the screen and its housing and put the battery in the recycle bin. Then, I go on-line and simply order a new one. Unless you have a really expensive razor, replacement parts and shipping costs aren't worth the trouble.
The second is that because I use mine in the shower, the contact pins & sockets on the charger & razor develop a layer of lime or calcium scale overtime. This thin layer of scale insulates the contacts from each other and prevents the razor from charging. At first I tried high-end "Cramolin DeOxit" but with no success. Then I poured a small amount CLR on the pins and sockets and scrubbed them with an old toothbrush. After rinsing with some clean water and drying with a paper towel and a few blasts of air, it charged perfectly! So, check your charge status light first to be sure you have a good pin/socket connection before leaping for a new battery.
Top Panasonic Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
 Mikey
Mikey
ADMIN Andrew
ADMIN Andrew
Are you a Panasonic Health and Beauty Expert? Answer questions, earn points and help others
