Question about Option Computers & Internet
I have a s55v16a-au and want to know how to use a usb. I have put it in but din't get an option to open it
    Habit-Forming:
    New Friend:
  • 149 Answers
Go-to my computer and click removable devices you Will be able to open the USB if autoplay is not set
Posted on Jan 05, 2018
6ya staff
SOURCE:
Keyboard is no longer working. i forgot how to connect to win7
If the keyboard isn't faulty and is a usb keyboard, your computer should recognise it and load the driver.
If it doesn't then restarting without the keyboard and then again with the keyboard should put matters right. If it doesn't then suspect a faulty keyboard or investigate further in the device manager and use the troubleshoot option.
A din or a ps2 keyboard must be plugged in before starting the computer or they won't be recognised.
May 13, 2016 | Computers & Internet
Dont get anny thing on my ruku 2 ilike utube and netflex
Your device has no WiFi capability so you cannot get Netflix or YouTube,on the road or at home (you can forget about finding and connecting to an OPEN Wi-Fi network on the road !). As far as watching YouTube videos on your device, there is a workaround: download the videos to your computer, transfer them to an SD card or a flash drive (the flash drive option may not work because the USB port on your device may accept flash drives only for maps or firmware updates for the GPS) or burn them into a DVD and then put the SD card/flash drive/DVD disc into the appropriate slot on your device. But I hope you do not intend to watch videos while driving !
Oct 18, 2014 | Crown Ouku 7" Double 2 Din In Dash Car Cd...
What size after market in dash dvd can I put in 2003 spyder gs
your radio/dash opening DIN size is what they call double DIN, to get the right unit fopr this u will need to know if you have a Facory Infinity premium sound system, it makes a diff in the model f the in dash units, here is a link to a site that has a selection of in dash DVD players for your double DIN dash.
http://www.crutchfield.com/S-nkinM0jziRR/cgi-bin/autoinfo/autoinfo.asp?id=&vehicleid=14718&vb=Y&TypeCH=&lp=%2Fg%5F168550%2FIn%2Ddash%2DDVD%2DReceivers%2Ehtml%3Ftp%3D20217&sl=Y
Aug 11, 2009 | 2003 Mitsubishi Eclipse Spyder
Does my dell dimension 2350 have a dvi port?
No, it does not.
Check the specs of your desktop PC here:
Ports and Connectors
Externally accessible:
Serial
9-pin connector; 16550C-compatible
Parallel
25-hole connector (bidirectional)
Video
15-hole connector
Keyboard
6-pin mini-DIN connector
Mouse
USB
two front-panel and four back-panel USB 2.0–compliant connectors
Network
RJ-45 connector
Audio
three back miniature connectors for line-in, line-out, and microphone
Headphone
one front miniature connector for line-out
Serial
Parallel
Video
15-hole connector
Keyboard
Mouse
USB
Network
RJ-45 connector
Audio
Headphone
http://support.dell.com/support/edocs/systems/dim2350/specs.htm#1107078
Jul 26, 2009 | Dell Dimension 2350 PC Desktop
F2 and beeping sound...what gives? How can I fix? Thanks!
open the cpu and din remove the memory and use the hair brush into the memory housing also applying hair brush into your memory and din put again into original position, and try to on it
Jul 04, 2009 | DCS WO-130 Stainless Steel Electric Single...
My gpx ml648b won't turn on I have the usb cord plugged in and I don't know if it's charging or not.
try to barrow to your friends other battery dsame model of your phone and din insert it din try to charge and on...if your phone charging that mains your battery problem... or use other charger
Jul 04, 2009 | GPX ML648B MP3 Player
De ce nu citeste de la subtitrare tot cuvintul?
CAN BE SOLVED IF YOU CHANGE THE CHARACTER CODE FOR SUBTITLE, LG= PRESS 5 SECOND ON SUBTITLE BUTTON AND SELECT ANOTHER LANG ID
Feb 01, 2009 | HomeTech HT503 Main / Stereo Speaker
What are the pin conections for external usb on an asus a7v400-mx board
USB mouse/keyboard to 5-Pin DIN or 6-Pin Mini-DIN adaptor USB Function 5 Pin DIN 6 Pin ps/2
Pin 1 +5V Pin 5 Pin 4
Pin 2 -Data Pin 2 Pin 1
Pin 3 +Data/clock Pin 1 Pin 5
Pin 4 Ground Pin 4 Pin 3
shield shield shield
Apr 16, 2008 | Computers & Internet
Honda Passport '98 compatibility
they are sized by a measurement system known as DIN. Yours is either a DIN 1 or a DIN 2, differentiated by the height of opening in dash. Simply put, the DIN 2 is twice as large as a DIN 1. If the opening height is roughly 2-1/2" high, you need a DIN 1 unit. Prior to the DIN rating system, many owners were frustrated over the 'FIT' incompatibility with various widths, depths and heights.
Sep 09, 2007 | Clarion ADX5255
Computers & Internet Logo
Top Option Computers & Internet Experts
Darren  Means
Darren Means
Marvin
Marvin
john h
Are you an Option Computer and Internet Expert? Answer questions, earn points and help others
