I would start by rebooting the device if you haven't already. Also go into your settings, Applications and select All applications if you can. Fin your application you use to download and install apps with, such as the Play store. Clear out the cache. Now try to download again that should fix it.
SOURCE: Downloads are not working..store says i have them but they are not on my tablet
Start by going into settings > Apps. Locate your application used to download/install, typically it will be the Play Store. tab on it and clear the cache, then force stop the application. This should clear out any bad data.
SOURCE: problem downloading games from the app store on all three of my new tablets
1st You download Webcam Driver.
Problem downloading games from the app store on all three of my new tablets
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
SOURCE: *I keep getting an insufficient memory error when I try to download apps
delete some heavy apps on your tablet or buy a new SD card
