SOURCE: I updated my exchange password on my laptop today
I've seen this happen with mobile devices sometimes, do you have any special characters? Make sure you're putting each character of your password in correctly. If you're certain that you are, log back in to your laptop and change your Exchange password to something simple like Password123. Wait about 20 minutes (it can take time for the password change to take effect across the domain) and try logging in with this new password. If it works, it was the password. If not, the issue may be on the iPad.
If that's the case, try removing the account from your iPad and re-adding your Exchange account. Hope this helps.
SOURCE: how to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
Your best source of help would be to call Apple. They go out of the way to support there products.
SOURCE: how do i factory reset apple ipad i forgot my apple id and password
Resetting the ipad will not help... The I'd and password are stored at the apple store.
SOURCE: i have an ipad that ask me for apple id that was used to erase this ipad.how do i get pass this
you do not , it is locked to icloud and the real owner is the only one that can open it , look on youtube you will see what I mean
