Washing Machines Logo
T
Tim Tam Posted on Jan 12, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Fisher and Paykel iw812 washing machine is leaving black spots on the clothes. I want to dismantle the drums to clean them but can not find info on how this is done. Any help much appreciated.
vince
Level 3:
  • Fisher and P... Master 2,530 Answers
  • Posted on Jan 12, 2018
 vince
Level 3:
Answers
2530
Questions
0
Helped
748666
Points
8845
  • vince Jan 13, 2018
    thanks!
  • ADMIN Andrew
    ADMIN Andrew Jan 13, 2018
    Napisan is a product for soaking baby nappies (diapers).
Paul P
Level 2:
Filmmaker:
Uploaded 5 video answers.
Scholar:
  • Fisher and P... Expert 80 Answers
  • Posted on Feb 27, 2019
Paul P
Level 2:
Filmmaker:
Scholar:
Answers
80
Questions
0
Helped
61409
Points
218
5 Related Answers
Anonymous
  • 27 Answers
  • Posted on Oct 25, 2008
SOURCE: I have a fisher and
Hi there. FC 49 has a few possiblities
1. the wiring connection to the cold water valve has been disconnected
2.the cold valve has failed, compare resistance with hot valve (they should be the same)
3 the motor controller has failed
I hope this helps
Anonymous
  • 15 Answers
  • Posted on Mar 10, 2009
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Anonymous
  • 145 Answers
  • Posted on Apr 20, 2009
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Anonymous
  • 3 Answers
  • Posted on Feb 20, 2010
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
luisa_sgro
  • 713 Answers
  • Posted on May 27, 2010
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
How to clean drum wont let me choose cycle ?
If it is really loud and noisy when on spin it will almost certainly be worn or rusty bearings. Workshop job to dismantle and replace the parts.
My Iw812 jumps across the floor and displays our of balance
I have the same machine in the laundry,(IW812)
This is normal for large bulky items to get stuck to one side of the bowl when spinning dry.
My washing machine IW812 has fault code 37.Could explain what that is please?
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
Dismantle washing machine fisher and paykel - unit smells -need to remove bowl to clean out
b4 u remove bowl try this 1/ buy 2 pkts bicarb of soda. 2/pour into empty bowl of unit. 3/select high water level 4/ select hot fill. 5/ start cycle 6/ let it wash for 5 to 10 mins then turn it off, do not let it get to rinse and drain the water away. leave it over nite with water still in it, in the morning restart program and let it do a normal cycle with no clothes in it. it will not refill as it already fill of water.please reply to see how u went or 4 more help
Black spots and smears on clothes from DRYER (not washing machine
Sounds as if your going for a spin. Not really here is where the problem could be. 1 the bearing on the mchine is going bad. Since the bearing is sealed with its own lubrication the seal has blown seeping the lubrication into the machine one the temp is right to cause the oil to flow. How is this possible you ask? it is possibly flowing down the drum as the drum rotates and entering the dryer from the front of the drum. I would remove the back of the dryer and inspect the area and if all is right with the stars you may not have to take that spin
Good Luck
Dave
Top Fisher and Paykel Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
