1) Check your power plug wiring and replace the fuse.
2) Read the Manual:
http://www.lg.com/us/support-product/lg-47LN5750
SOURCE: 2yr old Pioneer pdp-506 50" panel with seperate receiver unit
Hi Kricko
Your blinking light indicates an internal "board" issue. You should contact Pioneer Customer Service for initial help, but you will most likely need a TV repair shop to replace the part.
Good Luck
Pioneer (800) 421-1404
SOURCE: Sony KV34XBR800 Red Flashing Standby Light No Power
The red light should be blinking a code. For example it will blink 4 times pause then 4 times pause or 5times pause 5 times pause, whatever the error might be. Let me know what it is and then we can help more.
Tim
[email protected]
SOURCE: 5 red flashs on power/standby light on kdsr60xbr1 screen blank,
Thats the error for lamp driver error. Which means the Ballast is most likely defective. You can get the replacement ballast for your model at the following link which comes with installation instructions.
http://servicemanuals.vstore.ca/product_info.php/pName/kdfe42a10-ballast-assembly/cName/sony-parts
SOURCE: LG 50 IN. PLASMA TV MODEL # 50PC1DR . POWER
Power supply board is dead,replaced the power supply board will get power.
