There isn't a closed captioning on/off button on the tool/menu
A Google search suggested this:
To turn on and set the Closed Caption function options, follow these steps:
SOURCE: closed captions will not disappear
Some TV will not display close caption in HD mode. This is why its Grey out in HD mode. If you switch to regular input, i can bet you your close caption will not be Grey out. The problem you are having is your cable box has close caption enable. You must go into the cable box menu and turn caption off. In some box you may have to call your cable provide for assistant.
Best regards
Circuitcity
SOURCE: close caption
You need to turn on closed captions through the menu of your PVR. To have it on all the time, turn the box off, press menu on the front of the box, and scroll down to captions.
This should fix the problem
SOURCE: Closed Caption
On the universal remote hit the menu button then on the TV itself use the vol +/- to select and the channel +/- to move the it up and down. it that simple
Yeah, I'm now believing it's the tv. The captions on the other tv in the house work great. My samsung is only 2 yrs old. This model was 1080 i...Kinda of costly. Still no solution???? CR. LEE
SOURCE: how do i enable the closed caption on my samsung tv/direct tv?
Correct solution WITH DIRECT TV is NOT going to SETUP MENU on your Samsung TV and enabling it, this won't work with Direct TV!! I'll walk you through it. Grab your Direct TV remote, hit "Menu", pan down to "Parental, Fav & Setup", next click "System Set-up", next click "Display", now at the top of the screen between "Preferences" and "Clock" is "Captioning", click on it, now the first box reads Captioning TURN IT FROM OFF TO ON! You now have Captioning.
2.Press the up or down button to select "Closed Caption", then press the ENTER button
3.Press the ENTER button to select "Closed Caption". Press the up or down button to select "On", then press the ENTER button.
4.Press the up or down button to select "Caption Mode", then press the ENTER button 5.Press the up or down button to select caption mode you want, then press the ENTER button. Press the EXIT button to exit the menu. ok
