Question about Haier Freezers
I have haier hcm050wa 5.0 c.f. freezer. Trying to remove the thermostat sensor. Sensor will not pull out. Thanks.
3 Suggested Answers
6ya staff
SOURCE:
Ron4705
SOURCE: The thermostat is out on my Kenmore 14.8 cu ft freezer
I asked a local repair shop. Just pull ******* the sensor wire and it will slip out of the tube through which it runs. Run the new wire which is attached to the new thermostat thru the same tube. Prior to purchasing the thermostat, I tested with a ohm meter for continuity ( there was none) and jumped the attaching power wires. The compressor ran verifying the problem with the thermostat. Thermostat cost $47.00.
Posted on Jun 08, 2008
christian nielsen
  • 358 Answers
SOURCE: Haier HCM050WA, not cooling, compressor very hot
Try replacing the compressor relay , if this doesn't solve the problem ,probably the compressor is jamed or burnt and has to be replaced.
Posted on Oct 18, 2009
How many amps is required to run it?
There is a data plate on the rear with rated amps printed on it
Aug 05, 2012 | Haier 5 cu. ft. / 142 liter Chest Freezer...
I unplugged my chest freezer to clean it out, when I plugged it back in it won't get cold. It's in excellent condition. Never has it gave me a problem. It's approx. 5 years old. Ed V
Try turning the thermostat down to O and then back to max a few times this may free a stuck bimetallic strip. If this doesn't work and assuming you haven't damaged any components in some way then all that may be required is a new thermostat.
Nov 28, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
I have Haier 5 cubic foot chest freezer, model # HCM050LA, that cools well with the green light on. When it is running it makes a very faint high pitched sound that seems to be coming from the top right...
Yes it does. It will have to be blowing inside so look in there. You will have to take the cover off.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Oct 18, 2009 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Quit working -Haier Freezer
You have one of three issues here.
Either the thermostat has gone bad,
The thermal cutout has gone bad ontop of the compressor,
or the capacitor is out for the compressor.
Take an hom meter and check the thermal cutout, it should read 0 ohms or "continuity" if it doesnt the cutout is bad.
The only real way to check the cap is with a cap meter.
as for the thermostat check it with a n hom meter to make sure you have good connections internal the thermostat.
If you have any other questions just let me know!
Mar 12, 2008 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Haier 5.0 cu. ft. HCM-050 not freezing
Unfortunately this sounds pretty surely like you need to get your freezer checked for leaks and re-gassed; control on refrigerants these days makes it very difficult and probably illegal to try and do this yourself, but any refrigeration repair guy should be able to do the job. slight worry is that the compressor could have seized, but this is not so often the case, sometimes a sharp whack can unjam a compressor, but get the fridge guy to look at it if he does the gas. Hope this helps :)
Mar 11, 2007 | Haier 5 cu. ft. / 142 liter Chest Freezer...
Freezers Logo
122 people viewed this question
Top Haier Freezers Experts
Marvin
Marvin
Dennis Boxerman
Are you a Haier Freezer Expert? Answer questions, earn points and help others
