SOURCE: blower for nissan titan
The picture I will try to attach will show you the blower motor housing. The white electrical harness rt hand upper corner is attached to the blower motor resistor. If you have checked the relay and its working ( you can check with a tester) the resistor is probably the problem. It's the most common a/c blower issue I see weekly hope I can send it and hope it helps.
SOURCE: starter
The starter on the 5.6 L engine is located at the top of the transmission bellhousing. You have to remove the upper intake plenum to get to the starter. You can't really see the starter until the plenum is out of the way.
Hope this is helpful!!
Nissan Scope Technician- 10+ years experience in Nissan dealership
SOURCE: 2005 nissan titan,turn the key, the starter turns
Change the starter. The starter has a gear that moves forward, meshes with the flywheel, and cranks the engine over. From what you describe, the gear is spinning, but not advancing on it's shaft to mesh with the flywheel.
SOURCE: 2005 nissan titan, starter turns but engine won't
Hi Check and make sure the bolts to the starter motor are tight. The starter might sound like its working but its probably has a burnt solanoid. the third thing it could be is the ring gear is worn. Hope its not the last one. Good luck !!
