SOURCE: user manual in English for Sanei N90 16gb 9.7 tablet
how to change from chinese to english Sanei N90
SOURCE: I purchased a android 4.4.2 KitKat quad core
just buy it its cheep
if you want the game
try its demo first and see if you really do need it in your busy life
is it that important?? i still just play mame games from the 80s cheep and cheerfull easy on the mind and i get a buzz becouse i can key a credit up
i havent been able to do this after i use to use a piezo spark to get free games and credits in the days before chips had ECD protection
bo ho turns into yip e play mame
the 64 bit ui is magic and very tight works like a charm
don't think abuse is covered
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet
manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
Why do you need factory reset if you managed to get into settings?
Testimonial: "There was another account besides mine, but it was deleted, now its only my account and I have forgotten my pin and I can't access my settings from my home screen"
