How can repair my hcd-rv555da sony deck receiver display reject and switches off to standby just few seconds when powered on
Click link and download manual:
https://servicemanuals.us/sony/audio/hcd-rv222da-hcd-rv333da-hcd-rv555da-mhc-rv222da-mhc-rv333da-mhc-rv555da.html
SOURCE: Receiver shuts down and will not turn back on untill you unplug and plug back in
Nope. sorry to burst your bubble but your problem is pretty common on this unit. Its bad capacitors in the power supply and probably not worth repairing in a repair shop. since this is a solid state reciver, there are no user replaceable parts inside.
SOURCE: stuck in self check mode
Hi
Unfortunately, this is a common fault with these units.
Fortunately though, it can be fixed.
See my earlier solution show below.......
Ok guys, you asked for a fix for the DMR E55 Self Checking cycle. Here goes.
In 99% of cases this is caused by a faulty regulator on the main power board.
The power board is located on the right hand side of the unit. The regulator is IC001 which is mounted on a thin metal strip which acts as a totally inadequate heatsink. This means that this component constantly works at temperatures beyond its tolerance.
Because of this it usually lasts a couple of years and then starts causing problems. The Self Checking syndrome is typical. If the regulator burns out completely, it can take other components with it, blow fuses and scorch the circuit board.
If you are competent in using a soldering iron with care, order an STRG 6353 regulator. These can be obtained online from a number of suppliers.
Disconnect your DMR E55 from the power source and remove the lid. Next, remove the fixing screws from the circuit board on the right where the regulator is located. Carefully remove the multi connector on the left side of the board. Remove the screw above the power connector on the rear of the unit. The power board can now be removed from the cabinet.
Using a small pair of wire cutters, clip all five pins from the old regulator as close the the top of the board as possible. Undo the screw securing it to the heatsink and remove the old regulator which can now be thrown away.
Next, using your soldering iron, remove what's left of the pins from the printed board and with a solder ****** or desoldering braid, clear the holes ready to accept your new regulator. Be careful because if you over heat the print it can lift away from the board.
Use a little heatsink compound on the back of your new regulator, poke the pins through the circuit board and then secure it to the heatsink. I usually fit an extra heatsink on these units which helps to reduce heat and prolong the life of the new component.
Next, resolder the 5 pins on the print side of the board. Use a magnifying glass and make sure you haven't missed anything or bridged connections in error and caused short circuits.
Now put the board back. This can be a little tricky but it's easy enough if you take care. Refit all the screws and carefully reconnect the multi connector.
If you have followed this correctly, switch the unit back on, pop in a DVD and give it a try. Unless you are very unlucky, Your DMR E55 will no longer repeatedly self check and will operate correctly.
Whilst it saddens me to hear that some of you guys would toss your DMR E55s into the trash can for such an easily repairable problem, please do not attempt this unless you are confident in your own ability.
Finally, do check that the fan operates but remember it is temperature controlled and will not activate until it is needed. Do not assume it is faulty because you do not see it working straight away. I have repaired lots of DMR E55s and I have never found a single fan or fan control circuit to be faulty. That's not to say it can't fail. good luck...
SOURCE: idlcd32tv27hd comes on for 1 second then goes to standby
REPLACE 2-4 BULGING CAPACITORS IN THE POWER SUPPLY BOARD, PLEASE LET ME KNOW IF FIXED. THANKS
SOURCE: sony HCD-GNZ77D dvd deck receiver DEST ERROR
if your sound system gives you Desk Error or Desk Read Error, try cleaning it with a lens cleaner, they can be found in many forms in the market. If the problem still insists then your system's lens ( the part which read the optical discs like DVD's CDs etc.) need to be checked by a professional technician, probably would install a new lens on your system. You can comment if you need more clarifications. Best of luck
