That is a go!
This may not help but I had the same issue with a KenMore side by side with bottom freezer. We would shut it and it would bounce back open just a bit and not enough to notice at a glance and not enough to set off the 'door open' alarm.
I had to order the parts which took a week but fixed it for $10 or less and in less than 5minutes.
On the bottom of both my doors at the hinge is a plastic piece that is the catch. I had to be on the floor to see it but it was evident that it was worn.
Replacement cured the problem.
Testimonial: "Thanks. We have a plastic piece at the hinge as well but that doesn't seem to be the issue, although it makes sense that it would be since it does act as a catch."
SOURCE: Water pours down the back(Internally) ofmy Liebherr Frost Free Fridge freezer.
It is most likely a broken water tank in back wall of refrigerator section remove the crisper drawers you will see the tank it holds about 1.5 gal of water to keep it chilled for the dispenser. check all around it with the water on and someone getting water out of the dispenser at the same time check the seams closely. you should find the leak there let me know if not we may have to look into the water inlet valve
SOURCE: I moved our 18 month
Is the compressor trying to run at all. Are any sounds coming from the area of the compressor? Like a hum and a click sound in that order? If the compressor is cold to the touch it could be a control problem. If the compressor is cold there are two things that shut its power off. The thermostat which controls the temperature or the defrost system. If the compressor is hot the problem is compressor related.
SOURCE: Kenmore HE4T Washer Leak
there are 2 possible causes.
either
inlet valve leaking - turn water off and if water fill stops, it indicates valve leaking
valve being powered when machine off. this is very unlikely but to check, disconnect washer and see if problem stops
also, if drain is plumbed into a spigot on the sink trap, every time you empty the sink, some of the water will flow into the machine. to cure this, take the drain hose as high as possible under the sink in a swan neck
SOURCE: refrigerator door keeps popping open
Level refrigerator with front 1/4-1/2 bubble too high in front.
SOURCE: Fridge door pops back open
The seal on your door may not be sealing properly, when you close the door the seal helps create a vacuum which keeps your door closed firmly, you might need to replace the door seal, you could also try leveling your fridge by putting shimmys underneath the feet, you might also want to check to make sure there is nothing sticking out of your fridge such as drawers or food racks that may keep the door from closing all the way. good luck.
