SOURCE: bosch classixx6 1200 express
Turn Program switch to 6 o clock,hold RPM button turn switch to spin, release RPM button.Turn back to 12 o Clock .It should reset it ,Mine is a classicxx7 but should be the same...Marius
SOURCE: Bosch Classixx6 1400 express
Possibly worn brushes in motor.
Remove rear panel, remove belt, remove motor connector plug, inscrew 2 screws that secure the motor.
Lever motor back with a screwdriver, keeping hold of it as you do.
You will see the brushes at the terminal end of the motor.
If they are less than 4-5mm, they need to be replaced.
Refit motor and belt and motor plug. Test on spin
Plz rate my solution.
Thanks.
SOURCE: keep getting F17 and time
E:17
Read more: Bosch Washer Error Codes ' eHow.com http://www.ehow.com/list_7190513_bosch-washer-error-codes.html#ixzz1OJs6RoB7
SOURCE: my bosch classixx6 1200s express
Try this!
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
