SOURCE: Block incoming unwanted calls
no your mobile does not support call black listing features. there are some softwares available. i think your phone is not built with symbian operating system. Check whether your mobile supports symbian os. there are more call blacklisting softwares for Symbian os built mobile phones. Else if your mobile is java compatible then try to find some call blacklisting java softwares from websites
SOURCE: Block Numbers
you have to download the software from download.com. just look up pda/smartphone software.
CallFirewall - a freeware smartphone app
Whitelist, only callers and/or sms from list
Blacklist, no callers and/or sms from list
Accept only from contact list
Reject All Calls
Reject all calls beginning with ### (i.e. an area code or provider like everything beginning with 800)
Reject and send the rejected callers an sms message
SOURCE: I want to block unwanted calls
its have black list software for your probleam
if u use that software u can control them unknown numbers as u wish
to block a particular mobile number, if the contact is saved in your phonebook, do these.
1. press menu,
2. select settings
3. select application settings
4. select call
5. select all calls
6. select auto reject
7. scroll down and select reject list and add number.
8. select search and it will give an option
9. select from two options, call log and phonebook
10 select phonebook (this is because the numbers were saved in your phonebook)
11, once set and configured, check and enable auto activation
12. click save and exit the settings.
if the contacts is not on your phonebook.
follow the steps 1-9 but step 10 will be your call log not the phone book.
10. select call log
11. it will give you the phone numbers of all the person who contacted you, including those who sent you a message,
12. at the right upper corner you will see all, filter it through received message and it will give you those who sent you messages.
13. select from the contacts or numbers from the list.
14, select and enable auto activation
15, select save and exit the menu
