Question about Kyocera Office Equipment & Supplies
How to repair error c7980 in Kyocera printer
Printer kyocera
    Champion:
    New Friend:
  • Kyocera Expert
  • 250 Answers
Empty or replace drum unit
Posted on Mar 21, 2019
6ya staff
SOURCE:
Anonymous
  • 126 Answers
SOURCE: KYOCERA MITA KM-1500 ERROR CODE C7980
C-7980 - Means that the waste tonerresevoir in the process unit is full with less than 100,000 copies onthe unit.
Clean/ empty the waster toner and vac.Also clean the sensor.
You may have to change the Process unit if cleaning does not work.
Posted on Mar 02, 2009
Everett Lin
  • 990 Answers
SOURCE: ERROR CODE "C7980". I HAVE ALREADY EMPTIED THE TONER WASTE. WHAT DOES IT MEAN AND HOW DO I FIX IT?
Hello sir; The code you display which means waste toner bottle full, just dump it .
Posted on May 12, 2009
versa093
  • 46 Answers
SOURCE: Error occurred. Call servoce person. C7980
Waste toner reservoir overflow problem (when the total number of copies is less than 100 thousand sheets) You need a new pcu
Posted on Jun 12, 2009
Phillip Fultz
  • 29 Answers
SOURCE: error on kyocera C7980...how do
The toner waste container on this model is not designed to be cleaned out by the user. It is located on the Drum assy. If you did want to clean it you would first have to open the main cover (like you were going to add a new toner cart.) Remove the Developer unit (the one the toner is attached too). Then to remove the drum assy grab it by the two green handles and pull it out. The part that faces the back of the unit is were the toner is stored if you remove one of the sides you might be able to get the toner out. Be very careful do not use a vacuum unless you have a filter that can filter as small as .03 microns. The toner is main reason this is not recommended because its so small and not good for your health. The drum assy is rated for 100k copies. Usaully last about 70k to 80k before the message you got comes up.
Hope this helps if you have any more questions just ask.
Posted on Aug 24, 2010
Nikolay Boychev
  • 525 Answers
SOURCE: kyocera FS-1016MFP "printer error service
Code: 6000
Contents: Broken heater lamp error
The temperature won't rise by 1°C/33.8
°F during warming up and the heater is
turned on for 5 seconds.
°F during printing and the heater is
turned on for 5 seconds with the duty
cycle more than 60%.
Causes:
- Defective fuser thermistor.
- Broken thermal cutout or heater lamp.
- Defective engine/high voltage PWB.
Posted on Feb 21, 2011
How to fix kyocera taskalfa printer error c7980
empty the waste toner from the drum unit, removable covers on each side of drum unit
Feb 08, 2018 | Kyocera Office Equipment & Supplies
How to repair error c7980 in a printer Kyocera
remove the drum unit and empty out waste toner there are 2 covers 1 on each side use small screwdriver to pry off covers
Jan 20, 2018 | Kyocera Office Equipment & Supplies
Error Occured Call Customer Service C7980
Sorry This Is Not The Customer Service You Are Looking For..............
Jan 29, 2014 | Kyocera Mita KM-1815 All-In-One Laser...
Error occurred. call service person c7980 printer
try unpluging it(the power and the usb), count to 15 and plug back in
Jan 25, 2011 | Kyocera FS-1118MFP Laser Printer
Kyocera FS-1018MFP photo copier. Our copier has an error message C7980 which we understand means that the toner waste container needs emptying. Is there an easy way of carrying out this operation?
remove the drum unit. on the part of the unit that goes first in machine is the is waste toner container. on each side of the container there is a screw, remove one screw and pull out the cover. slant the unit and the waste will come out
Oct 05, 2010 | Kyocera KM-1505 Copier
Se produjo un error llamar al tecnico C7980
On the screen of my KM 1820 copier Kyosera get the message "An error occurred calling a technician" and C 7980
how I can fix this error?
Sep 03, 2010 | Kyocera Copystar CS-1820 Black and White...
What is error code c7980
this is drum related error. empty waste toner from the drum unit
Aug 20, 2010 | Kyocera Copystar CS-1820 Black and White...
Jun 05, 2009 | Kyocera FS-1118MFP Laser Printer
May 12, 2009 | Copystar CS-1820 Copier
Mar 02, 2009 | Kyocera KM-1505 Copier
Open Questions:
176 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
