SOURCE: red flashing eye
The flashing eye indicates that the red eye minimizer feature is enabled. My NV 10 has buttons on the back that line up with features on the screen. Try to find the one that looks like an eye. That option is often times tied to the flash feature. The flash may be able to be turned on with the same button.
Kay
SOURCE: camera wont take pictures with a flash
Try reformatting the camera. Take the memory card out first or else you might lose all your pictures.
SOURCE: Olympus 1030 sw -Flash doesn´t work anymore
Have you tried to reset the camera to the factory defaults? To do this: have the camera in shooting mode - go to Menu - left arrow to reset - press ok - Highlight Yes and press ok. This will reset the camera to factory settings. See if flash works now.
SOURCE: Model MV6i Camera works but have flashing red
This symbol means that your backup battery needs to be replaced. It is a "button battery", type CR1616. Instructions for replacing it are in the manual, which is available to view or download here.
SOURCE: Initialized camera (Olympus sp800uz) and can't get
As describes in the user manual page 15, After putting ON the camera, you can press the Menu button to get the Function menu and to set the mode you want, using the Left/Right direction of the wheelcontroller. (How to use the camera menu, see page 4 of the user manual.)
