SOURCE: i am not able to view my files from my computer option
i am not shure but make shure it a aloud to view
on the camera setting
SOURCE: picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
SOURCE: Olympus Stylus 710 Problem with lens
Turn on camera. Blurry pic. Wirly grinding noises. Blue screen.
Codes on blue screen:
5 f 0 8
5 e 0 2
5 f 0 8
5 e 0 2
Sometimes smacking the **** out of it fixes it. Today it doesn't seem to do the trick any more.
Suggestions?
SOURCE: Olympus Stylus 1030 SW display not working after being in water
I just had a similar problem. I am not sure how it was fixed, but it works again - at least for now.
I had the camera on and was taking pictures when the screen went dark. Same as you describe, it takes pictures, flash works, LED, works, everything but the display. I plugged it into my computer with the USB adapter to see if I can salvage what is on the card and the diplay lights up. Tried several variations, but when the cable is connected to the computer (didn't have to be connected to the computer) the screen worked. Unplug, no display. I spun the settings button a couple of times. I accidentally took a couple of short videos and pictures that I deleted. I unplugged the camera and powered down again (tried that before). Power up and the screen is fine.
Again I have no idea what fixed it or why the display worked with the cable plugged in. It might have been related to the videos or some setting that I had slipped into (thought the display button never worked or changed anything).
Hopefully something in there helps or someone can explain what I did.
SOURCE: Cannot open file
Sir, I was working in a PM file. Computer shut down before closing the file. While opening the file Showing " Cannot open file. closing publication, some work may be lost. open the previously saved publication (8009:20551) "Continue" While clicking continue not opening the previously saved file.
