When i turn on the machine it shows; shutting down .... please wait main powere will be turned of automatically , maximum waiting time 2 min
Did you try to change another HDD??
Try memory in slot.
Try to change FW.
Change Printer Control Board
Bad HDD
Try to format in sp mode (sp5832)
If sc still appears replace HDD
There is a corrupted print job in the print cue you will need unplug the network cable from the machine then reboot the machine from the hard switch with the network cable still unplugged if the machine then comes to ready. You will need to contact you IT to get the corrupted print job deleted from the sever. When this has been done then plug the network cable back into the printer and you should have no error and be able to print.
Bad hard drive? unplug it an turn on unit. -Carl
SOURCE: Tascam DP01 wont get past please wait screen
Usually an indication of bad sectors on the hard drive. This can be caused by bumping the unit when it is running, excessive vibration, a power failure while it is on, improper shutdown, or expoure to a strong magnetic field like having a subwoofer too close or an intermittent faulty power supply.
Your options are to return the unit (if it is still under warranty), or if not to open up the DP-01, remove the hard drive, connect it to a PC and perform a low level format (or take the drive to your nearest PC repair shop and have them reformat it).
Unfortunately you'll lose any data that wasn't backed up, but this should bring back your DP-01.
SOURCE: Compaq Presario S6000nx pc wont start up
check the connection of your wires through your motherboard? try to reseat those connection( caution: you must have an assistance of any qualified personnel or technician because if you reconnect it in wrong position,this will result the motherboard to burn)
BE CAREFUL!!! but this will help..
SOURCE: Daewoo DF 4100P not turning on but showing WAIT...
I had this problem yesterday, and then i noticed that i had accidentally put the timer on. i had to unplug before i could release the dvd and set the machine up again.
SOURCE: Ricoh aficio 3025 says PLEASE WAIT and stays in this mode forever
Check for SC codes.
Check the following probabilities;
Good luck and please rate me, thanks.
