My smart tv is beside my computer. My computer have a cheap dlink wifi adaptor and get 85% signal. my tv signal is so weak I have signal or none at all. Is it the same as most laptop adaptors? Can anyone reconmend a good adaptor to put in?
Just get a WiFi extender...this will definitely increase the signal..the tv adapter is generally built-in, but the software might be upgradeable...cheers
I'll go buy one tomorrow.
Thanks alibaba69
No worries mate.. cheers
I bought a $35.00 Netgear and my problem is solved. Thanks again alibaba69
Glad to hear it, the thats the one I use too... cheers
SOURCE: Belkin N1 Wireless Adaptor not connecting on PC
what the adviser meant was your pc cannot provide enough power to the usb port to power the unit, assuming you have tried other ports and it still wont work; you will need to either purchase a pci usb 2.0 card adapter or purchase a mains powered usb hub and connect to this instead.
SOURCE: AC ADAPTOR 090-02180-I3
Here's the only place I know that sells them:
http://stores.ebay.com/LCDPAYLESS_LCD-monitor-Power-Supply_W0QQcolZ2QQdirZQ2d1QQfsubZ2195941QQftidZ2QQtZkm
It seem to be the #1 common problem with the Protron TV.
It maybe cheaper to find someone to fix the power supply, but if you get it from LCDPAYLESS, make sure it has some type of warranty on it. I hate to see anyone pay $130 and it only last a couple of months.
SOURCE: Hooking Sanyo TV up to a computer
you need a hdtv tuner Hidef is different format than the rca jacks and digital won't worrk sorry.
SOURCE: My Netgear Adaptor keeps scanning after is found my wireless netw
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it.
now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close.
restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it.
now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2.
your connection won`t drop after this.
this will fix your problem...
SOURCE: Netgear wireless USB adaptor (WG112v2) compatibility problem
If your laptop has windows VISTA then perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a password setup on the router enter the security key.
7. This should setup the wireless network.
If it has windows XP then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight thee SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
