Saeco 7P Not Dispensing Product
Rick:
Here are some possible causes:
- for the top five selections (the ones that use espresso), the first sound you hear after making a selection should be the grinder starting. If no sound, check that grinder is receiving 120V.
- do the bottom 2 selections work (the ones that don't require espresso)? If not, inspect the ribbon cables leading from the selector circuit board in the door. The is a sharp edge on the door hinge which could damage these cables.
- if the selector circuit board was ever removed, it may not have been replaced so that pushing the buttons on the door actually depresses the microswitches on the board. To test, verify that you can feel a click when you push each button.
- it might be a circuit board issue. Having two machines allows swapping of circuit boards between machines. Hopefully, you can come up with at least one set of functional boards.
- Good Luck!
