M
Milagros Irizarry Posted on Jan 27, 2018
Samsung TV modelUn55mu6290fxza can I connect a Bluetooth speaker to it
How can I connect wireless headphones to my Samsung 55 TV UN55FH6003F that has no audio outputs?
I don't know if the OS on the UN55FH6003F will work with a USB bluetooth adapter; it would depend on if it can find the driver. A Bluetooth audio transmitter is more likely to work. This is one example: https://www.amazon.com/Bluetooth-Transmitter-Wireless-Headphone-Speaker/dp/B0838YPSZT/ref=sr_1_3?keywords=bluetooth+transmitter+optical+input&qid=1686438206&sr=8-3 . This model comes with various audio cables and a power supply.
I hope this helps.
Samsung curve 65 inch has no sound, has picture.. Using Bluetooth curved sound bar, no sound on tv speakers either
Hi!
Check your power amp circuit. Or, check if it is feed by the power supply circuit. Good luck,
Serge.
Purchased iLive Bluetooth HD soundbar 32", hooked up to TV and makes noise when on a HD channel, Samsung tv
iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat ...
www.amazon.com/iLive...Bluetooth-Sound-Bar/.../B0...
Amazon.com, Inc.
Rating: 3.7 - ‎6 reviews
iLive HD Bluetooth Wireless Soundbar Speaker TV Stand For 20-55" Flat Panel HDTV's Up ... when you purchase $5.00 or more of Qualifying Items offered by D.R. Worth and Sons. ... The iLive Bluetooth HD Sound Bar for 22 - 50 Inch Flat Panel TVs is cleverly designed to ... Click here to make a request to customer service.
Amazon.com, Inc.iLive iTB174B Bluetooth HD Sound Bar for 22 - 55" Flat Panel Televisions ...Bought another for a relative. ... **2 things to NOTE: 1-make sure there is nothing aside from your tv on top of the speaker to avoid rattling, which i mistook for distortion/blown speaker at .... It sounds much better than the Samsung internal speakers.
How to Connect Soundbar to TV ' Audiogurus Store
www.audiogurus.com > Learn: Home > Displays
2answers
Wireless headphone connection on Samsung UN40H6203AF
Are the headphones regular wireless (with a transmitter, sometimes called base or dock) or are they Bluetooth headphones ?
2answers
How do I connect my Sharp HT-SB30 soundbar to Samsung UHD7500 TV
Should be able to use Bluetooth. Need to "pair" the devices (the TV and the soundbar). On soundbar, press On/Standby to power it on, press Input to select Bluetooth (pairing indicator blinks), press & hold pairing button until pairing indicator blinks quickly. Now go to the TV's setup menus: Sound > Speaker Settings > TV Speaker > SoundShare Settings, Add New Device=On, select the Sharp GT-SB30 from device list. If passcode, password, etc is needed, enter 4 zeros (0000). After the devices are paired. the pairing indicator on the soundbar should stop blinking. The pairing information should be retained so you only have to do this one time unless you do a full reset on the TV or soundbar.
2answers
How do I connect ilive Bluetooth speakers to my tv?
If your TV is not Bluetooth-enabled (I have not yet read or heard about a Bluetooth-enabled TV model), you cannot connect any Bluetooth speakers to it.
Connect bluetooth
Go to Settings > Bluetooth > (Find the speaker you are trying to connect to and delete it from your "Paired Devices" list.)
Then, try it again! Voila!
Connected Auvio Bluetooth speaker to Samsung LN-S3241D TV via digital optical wire and digital-to-analog audio adapter; the sound plays great but the volume can not be adjusted with the speaker controls,...
Check your menu on the Samsung to switch audio out selector. You might have to use ANALOG outputs instead.
you could then eliminate digital to analog adapter.
Analog out uses the RCA PLUGS.
2answers
Connect an active soundbar to a receiver
What if the soundbar is Bluetooth? Will I still be able to use that function and connect the active soundbar to the tv (Bluetooth) and connect the av receiver for other surround sound speakers? (they are pre-wired in the walls in the apartment I moved into)
Top Samsung Audio Players & Recorders Experts
ZJ Limited
ZJ Limited
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
