Depends on the type of DVD player you have. If it’s a portable, you may be able to push down on the top cover and it should open. If it’s in a computer tray see if there’s a little pinhole that you can stick a needle in and cause it to release. If it’s neither of those two types, then you should look on the console for a triangle with a bar underneath and press that button when the power is on.
Testimonial: "Thank you the help. Very prompt reply"
in the time it took to write this you could've pressed each button to find out,if none work,then you need to program a different number for the dvd player,not all codes operate every player
