Want to program direct tv remote to my element tv
This site was not
helpful at all
Element TV remote codes
Codes to operate your Element TV:
Newer codes 5 digit:
11886
10178
11687
12183
Older codes 3 digit:
046
005
028
043
048
076
096
155
004
051
127
151
153
154
231
236
238
247
252
168
121
ON MOST REMOTES:
1. Turn on the TV.
2. Press and hold the TV and SEL buttons simultaneously for 3 seconds. The button will light.
3. With the button lit, point the remote at the TV and enter the TV's 3, 4, or 5 digit code.
4. Verify by pressing the VOLUME + button. This should turn the TV VOLUME up.
5. Press the TV button to store the 3, 4, or 5 digit code. The button will blink twice to confirm the code is stored.
Your Element TV can be controlled with a universal remote and work with RCA remotes, Comcast, DirecTV, Charter, and more.
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC3220
just right click and save as on the download links.
if this does not work you can try the search method,
you do
this by either holding down the device button eg: TV or if you have one
the "magic" button for three seconds, a light should then flash twice
to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
SOURCE: Trying to program my DIrect TV remote to work my ILO TV
i have two tvs 1 is an Ilo and the other is a Sylvania. the code for sylvania works for both tvs on the Direct Tv Remote Hope this all helps and here is the code. 10171, there are also two other codes for this tv and they are 10054, and 10030. Have a good day and happy watching.
Darklove_420
SOURCE: Remote Control Code for Element LCD TV -- & Direct TV
We cant find our original element remote control. I just tried 10178 on the direct tv remote control and it worked YEAH!!!! We just can't do the screen size edit thing with it :(. Might still have to order a replacement element remote. This works for now. Thanks.
SOURCE: need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and
allow power on and off while in TV mode. This worked for me on the RC32
remote control.
SOURCE: I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
