Washing Machines Logo
A
Anonymous Posted on Jan 29, 2018
Why does lg top load washing machine (WT5001CW) keep blowing control board fuse?
Replaced control board and fuse blew again after 5 washes
Sock Puppet
Level 3:
Loyalty:
Visited the website for 30 consecutive days.
  • Master 322 Answers
  • Posted on Feb 03, 2018
Sock Puppet
Master
Level 3:
Loyalty:
Answers
322
Questions
0
Helped
112716
Points
1777
How old? Motor brushes worn or motor commutator fault maybe?
3 Related Answers
Anonymous
  • Posted on Jun 15, 2008
SOURCE: Fuse keeps blowing
This is probably a water heater problem  Try operating on the lowest temp  eg.15C If it goes through the cycle then its more than likely your water heater  You will need a refit
Anonymous
  • 77 Answers
  • Posted on Dec 03, 2008
SOURCE: fuse keeps blowing out in my maytag washing machine
replace the complete lid switch ***'y. be sure to adjust properly.
Anonymous
  • 3361 Answers
  • Posted on May 20, 2009
SOURCE: Maytag washer blows 1.5A fuse in back of the top compartment where the dial etc is
There is a micro switch next to the fuse. It is shorted out. Replace the micro switch and solve your problem.
Was doing laundry, machine just stopped. Full of water and clothes. Checked breaker, plugged in.... Will make power up music tone, but no lights on control panel. What to do?
The fact that the machine power up tone is audible indicates that the machine is receiving power which eliminates the fuse problem. I suspect that the main control PC board is faulty.
I have an lg washer model # wt5001cw i have a code le overload protection how can i reset this code
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective.
2answers
Wash machine LG wt5001cw won't turn on
I have a LG wt5001cw top loader washer and after it completed its cycle it shut off and will not turn back on. How do I fix it?
House fuse blew and now there is no power on LG WM2277H washing machine
Did you replace / reset fuse? Turn on washer again if it blows unplug it, unit has a dead short inside.
Washing Machine won't turn on
the rating, is that the same with the original one.?
try running with no load, maybe the motor got problem. if okay no load. try run with a little load. if still blow the fuse even no load test. Your problem is in the motor. Or monitor carefully when the fuse blew, is it when the motor run ccw or cw?
2helpful
4helpful
2answers
LG WASHING MACHINE WM14225FD
My machine would not switch on this morning, no beeps or lights, I traced it to a small fuse on the main circuit board. you get to the board by disconecting from the mains, removing 2 crosshead screws at the back of the machine and lifting the top of the machine off ( once screws out, slide top of machine back about 1cm and then it just lifts off. You can now see the main circuit board, behind the control panel on front of machine. the fuse is hard to see and is solderd to the board on the lower left side, I solderd onto both ends of the fuseand replaced with a 10 amp HRC fuse, I still need to find the correct fuse rating, this worked for my machine.
However, and its a big however, If the 13amp fuse in youre plug blew and the trip on youre consumer unit, then I would imagine something big (pulling a large current) has gone down in youre machine to cause all these to blow, anyway hope this helps, Robin.
2answers
Fuse keeps blowing out in my maytag washing machine
the power surge probably shorted out something in the main wire harness or fried your motor. remove the screws from the control panel and look for any wires that are discolored, charred or disconnected. in the event you do't find it there trace the wiring thru the cabinet looking for the same thing. if you don't find that, replace the motor
Top LG Washing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
