You may need to change the frequency of the chime. In this model, you need to remove the batteries from the receiver unit and wait for a while. Then replace the batteries. The doorbell unit should automatically set itself to a different frequency once you press the button, which will(hopefully) solve the problem.
It seems impossible to find the instruction manual for the doorbell. But see http://oddsnsods.net/blog/?p=68 who had a similar problem with a different Siemens model, which works on the same principles. (I can't seem to be able to remove the battery from the door bell unit on the jsjs204, but it reset itself after changing the batteries in the receiver).
Sandra, the contacts in bell push may need cleaning, as well as some minor readjustment of the contacts. Insects love to get into the bell push and can clogged it up. If you find that this doesn't solve the problem, Contact the Zenith Company 800-858-8501 to purchase a replacement.
Mary, there is a small button on the face of the face of the pusher. With the unit plugged in, push that little button and it will play the next available ring tone. When you find one that you want to use, simply stop and that one will be what you hear when someone comes to the door.
From User Guide:
Interference from a similar unit operating nearby:
a) simply remove the batteries from the push button and door chime units and rest for 10 seconds, this will erase memory
b) Insert the batteries into the push button and door chime units, the door chime unit will give 2-beeps to indicate that it is ready for the new registration code. Press the Push Button once, it will generate a new operation code randomly and send a wireless ignal to the door chime unit and it will sound to indicate that new operation code is registered and memorised.
(Note with this unit SX85R the door chime is mains powered, not battery powered, but above instructions are the same)
I believe there are either dip switches (or old-fashioned "jumpers" in both the button (the 'transmitter') and the dinger (the receiver). See if this is the case, and that the dip switches (or jumpers) are in the same position in both units. Then, simply switch one of the dip switches (or jumpers) to another 'position' in both the button and the dinger. There ya go...
