TECHWOOD 50inches TV Wall Mount Bracket TV BRACKETS TV WALL BRACKETS...
You need to get a proper bracket for the TV. Some TV units use a vesa mount but the Techwood uses a much larger mount. If you look in the manual for the TV, it will call out the bracket size in mm. You can order and go from there. Fairly simply process.
Semper Fi,
Z
SOURCE: 42LC7D-AB cant find bolts to fit for wall mount
http://www.scribd.com/doc/6399173/LGTV
here is the owner manual. look on page 16 and you will see one way to wall mount. Ragarding the size of the bolts needed, go to the hardware store and get one bolt of each size close to what u think u need and use the trial and error method. OR go to an electronics store and ask one of the techies. Be nice and they will help u for free.
SOURCE: samsung tv wall mounting
For a true flush mount installation, you will need to recess your connections (i.e. power, HDMI, S-Vid, etc). Most tvs have the connections coming out of the bottom to allow flush mounting.
If your wall is not drywall, or you really don't want to bother with the expense of recessing your outlets and cable connections, just get a swivel arm mount. It will allow the TV to sit a bit further from the wall and still look ok.
Go to www.monoprice.com for great deals on mounts. I have 3 of them in my house and they are excellent quality.
SOURCE: cant find any wall mount bracket that fit this %%$
buy basket from murugan stores and keep tv in that
SOURCE: I have a Sony plasma
here is a link to the perfect bracket for this plasma. it has everything needed and is what i use to install a 50 in sony the other day.its carried in walmart stores to
http://www.google.com/url?sa=t&source=productsearch&cd=2&ved=0CF0QgwgwAQ&url=http%3A%2F%2Fwww.walmart.com%2Fip%2FLevel-Mount-Fixed-Mount-Fits-34-65-TV%2F10056403%3Fsourceid%3D1500000000000003142050%26ci_src%3D14110944%26ci_sku%3D10056403&rct=j&q=walmart%20wall%20mounts&ei=TnmCTc68E4O4tgfGh6XWBA&usg=AFQjCNH0dJF90t9G9MeTKS6gcbdk0WOYLw&sig2=84aML2R7KxsHAfYi3M9P0Q&cad=rja
i also like this model as well
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4318066&CatId=2462
Actually,
wall-mounting your TV is a pretty simple task. You'll need to buy the right
bracket to fit the size of your TV and also meet the right distance range you
want. The procedure is explaining in every bracket you buy and involves
drilling a couple of little holes in the wall.
