SOURCE: How To Set-Up Email Account On Prada Phone
You must set up the accounts via desktop PC (or MAC) and then you you can access via the applications or mobile web pages on your phone.
SOURCE: Google talk used to open my Google Apps GMail
"uncheck"
the remember me in this computer Gmai these why is opening.
Let me know if this solve the problem
Your rating is very important to me
Was this helpful?
SOURCE: Hi, I just bought a
Here are the instructions on how to set this up, it is the same for my school which ends baruchmail.cuny.edu.
http://www.hsl.virginia.edu/services/howdoi/hdi-android.cfm
SOURCE: my daughter entered the wrong
For all android devices a google mail account is needed for purchasing apps etc. if he did not set this up and had set the pass code without the email specified the only way to get back into the phone would be to do a complete reset. Before you do this have you tried restarting the device and seeing if it gives you the ability to try to enter the code again, if not here is how to do a factory reset. As stated below this will delete everything on the sd card so i would advise you copy all the files from it onto your computer. the entire process should only take about 10 to 15 minutes depending on the phone sometimes less than this, good luck!
Performing a factory reset (hard reset)
If you're passing your phone on to someone else or your phone has a persistent problem that cannot be solved, you can do a factory reset (also called a hard reset). This returns your phone to the state it was in before the first time you turned it on.
Note: Factory reset will not remove the data and files that are in your phone's microSD card.
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset.
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
SOURCE: [email protected]
o cancel a Gmail account and delete the associated Gmail address:
