SOURCE: Sony Mini Hi-Fi Component System (MHC-RG660)
I understand the problem. It should be the relay which is not responding, technically not able to connect the system power supply, you will have to replace the relay. The STK chip should be working fine.
SOURCE: Phillips Eye Fi television sound not comming, momo
enter serv mode by following sequence
062596 display or menu
check option bytes , opt byte sticker is pested on crt or backcover correct the values problem will be solved
SOURCE: I need a owners manual for a Sony Mini Hi-Fi
Click Sony Support to download user manual of MHC-GX250
Thanks.
SOURCE: owners manual for a Sony Mini Hi-Fi, component system,MHC-GX250
You can download the required manual from:
http://esupport.sony.com/US/perl/model-documents.pl?mdl=MHCGX250
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks.
SOURCE: I need the code for a Teac CD-X10i mini hi fi
I can help you program your Logitech Harmony 520 remote for your Teac CD-X10i.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software
you can download from here.
Once installed, you will simply
run the software, and select the devices you would like to control from
menus. The software finds the right codes for you and loads them into
your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual
Download
Logitech Harmony
Firmware Update
Harmony Win Software
Download
Logitech Harmony Safe
Mode Fix
Harmony Remote Glow
Light Fix
