Master reset with hardware keys
Turn on / off
Good luck !For the most part, the days of just taking the batteries out, and leaving them out overnight are gone.
SOURCE: Is there a way to
Yes : boot from the recovery partition (you'll need to give the boot process some more time to keep the choice of the bboting partition displayed :
Windows+Pause, Advanced, 3rd "Parameters" button, change to 10 seconds.)
SOURCE: a13 tablet launcher not working due to density
I just did something exactly like this on my phone. Here's what I did for solving it.
NOTE: you will need access to a PC with internet connection and your problem Device must have access to the internet. You also need access to the PLAY store on both the PC and the problem device. From what I understand from reading your explanation this should not be a problem.
1 - Start your Device as normal and when you get the force close message go to the Report option.2 - Once on the report screen (accept the terms and conditions if they appear) you should be able to pull down the notifications bar.3. On the PC go to the play store (you must log in with the same account as the one in your problem device)4. Search for a different Launcher and install it through the play store on your PC. (I used Zeam Launcher for resolving my issue but I did this on a phone so it might not be available for a tablet. You can search for Launcher and find one that way)
5. The new launcher should automatically start downloading and installing on your problem device. You should be able to see this happening on the notification bar.
6. Once finished, just go back to the main screen. You should get the option of what launcher to use. Select the newly installed launcher. (do no use the default option).
7. Once in the new launcher, go to the density changer application and change it back to the original density.
8. Reboot your tablet and it should now work correctly.
NOTE #2: I did this on a phone. I've never owned a tablet so I'm not 100% sure this will work for you.
Hope this helps solve your problem.
SOURCE: Model # rct6378w2 ... an rca tablet ... i cannot
Have you tried this? http://rcatablets.com/sites/default/files/Tablet%20recovery%20mode%20to%20wipe%20data%20Android%204.1.pdf
SOURCE: how do I bypass pattern lock on my Proscan PLT7223G tablet?
Zolygon Factory reset Proscan PLT7223G Android Tablet
Please watch the video and try the link given
